Gentleman's Bowie & Sheath
This Bowie is by an up and coming maker: Chris Daigle of Houston, TX (DAIGLES@sbcglobal.net). This was the knife that triggered my Mexican Loop Tutorialback in January. This particular sheath is a variation on the traditional Mexican loop theme - a narrow belt loop with a riveted cross loop to eliminate the bulk of the traditional skirt. After I got the knife I realized that the finished rig would have looked sort of wide and stubby with such a big skirt and Chris agreed. Good lines are the main parameter of my work. Chris is the best kind of customer - he gave me a general outline of what he wanted and then let me take it from there.
Here are the specs on this very nice, well balanced Bowie - 5/32" thick 5" blade- ATS-34 stainless- flat ground- hand rubbed to 600 grit.
416 SS guard- satin finished, Copper ferrule, Mosaic pins
Coffin shaped African Blackwood handle.
Sheath specs:
The back and belt loop are of 7/8 oz vegtan with the cross over loop made from 4/5 oz. The welt all around is made of 3/4 oz which is more than adequate. With a period sheath of this design the blade must be fitted snugly as there are no retaining straps and when made with a thinner welt it works very well for retention without being too tight (leather always has a certain "give" to it).
The front is actually two thickness - an inside layer of 5/6 oz covered with a 4/5 oz layer that makes the arched throat cover that aids in retention by lightly gripping the crossguard. The outer layer is glued to the inner face and then the whole thing is sewn using Barbour's Redhand 5 cord linen thread using the traditional harness maker's/saddler's stitch.
Note the two small tacks that prevent the body of the sheath from pulling up through the loop when drawing the blade. I've come to use these on almost every sheath of this style because no matter how tight you get the cross loop eventually it will stretch a bit and loosen up.
The color is my favorite medium dark, aged russet. Unfortunately the rich nuances in the color aren't fully apparent in these photos, although the backside photo gives you a taste. I started to do this one plain, but it just cried out for some deco and this fairly plain style of incised carving that I really like fit the bill perfectly.
This whole rig, knife and sheath, is one of those rare but very pleasing gems that just came together without a lot of effort. Hope you like it as much as I do.
Chuck
Looking good, Chuck. See what March brings, its got to be better than Febuary. If something moves for me maybe we can do a joint thing soon.....Ray
Sweet!! :eek: :cool:
Looks like the blade would draw very quickly.
Although this probably isn't the compliment you're looking for, it's very kydex-like in design ;) :D
Andrew I'll take that as a compliment in the spirit it was intended.
How about Frontier Tactical?:)
Chuck that is beautiful! Thanks for sharing, and the description helped me see what you were doing and how it went together. Did you add welt thicknesses near the guard to allow clearance to the belt loop? Or how did you manage that? That's my hardest area to get right.
Thanks again,
Dave
[rant on]This one of my pet peeves. I find too often that guards are too often too "high" off the blade. In the majority of the original Bowies I've handled (quite a few over the years)the guard was never more than 1/4" deep here. Many if not most of the modern repros are upward of 3/8" - just too much.[/rant off]
Anyway my solution. If you look close at the back you the sheath you can see that I made it so that the stitching starts about 3/4" down from the top. This allows the loop to "kick back" a bit. It can be done even with a standard loop.
Here's a closeup of another sheath showing how this is done.
I also sometimes use a 2-3" long wedge to add thickness. Look at the tutorial mentioned above and you can see a drawing.
Chuck
Thanks all.
Bruce I'd dearly love to make a rig to match one of your pistol/knife pieces - it would be a real challenge.
Good Stuff Chuck!!
By the way, I always kinda thought the Bowie was the "Old West" tactical.
Finished my dirk had to drop the "Scottish" moniker. The customer preferred a slightly different handle style than the traditional black thistle or knot look. I'll email you some pics when I get a chance.
Carl Rx
