Found this today at a local thrift store at a favorable price. Totally loose on the handle, but that was OK as PO had drilled the side of the blade and installed a sheet metal screw!
Am curious what the original weight and dimensions might be as I try to figure out how much I can sharpen it.
Weights 1lb 9.5 oz
Across the top is 6-3/8"
Across the blade is 3-3/4"
The "G" in Genuine lines up over the "r" in Norlund
The vertical part of the "E"in Genuine lines up with the stem in"d" from Norlund
Weights 1lb 9.5 oz
