- Jul 23, 2015
I have been doing some testing lately, just to try and get a better feel for striking a good balance between toughness and cutting ability. A knife that can chop or baton through a nail is going to be obviously very tough, but how well can it cut? And a kitchen slicer ground full flat to 8 or 12 thou behind a 15° primary edge is going to slice well, but I'm starting to think no matter the steel or heat treat, you're still going to take a half moon chunk out of it if you try and cut a nail.
So basically I am looking for opinions and input on just how thin you think a knife should be and still be able to baton a nail, and whether the baton nail test really matters. Should an outdoor chopper be able to baton a nail? If so, won't the geometry sacrifice some bite? And if it will sacrifice bite, then isn't it better to just be careful not to hit rocks, and instead have thin geometry that can bite deep and send chips flying? I know it's all about compromising characteristics, and I am basically just looking to hear others' experiences, anecdotes and opinions on this topic of geometry and the balance between cutting ability and toughness.
Thanks
H1 Aqua Salt plainedge, ground to a thick 15° convex edge and 20° micro, about .030" bte, cut through a nail and showed no damage beyond a little edge roughness that honed out in a couple of passes on ceramic.
H1 Salt 2 Wharncliffe plainedge, reground to near zero, dropped accidentally tip down onto portable carpet square, underneath which was concrete foundation, ~1/8" of tip bent right over.
AEB-L listed at 62.5 RC, ground to .012" behind the edge, spear point tip, 1/16" of tip stabbed into maple, and pried, bent twice, snapped off the third time.
AEB-L listed at 61 RC, .020" behind the edge, batoned a nail, took small half moon chunk out via catastrophic rolling.
8670 ground to .012" bte, catastrophic rolling and chipping when attempting to baton nail.
Reclaimed sawmill blade steel, ground to convex, 15° primary edge, 20° micro, .035" behind the edge, baton nail and showed no damage.
Final note: I made a seax early last year in 1084, tempered to 450°. I ground it to full height flat-vex, with a 15° per side primary edge and 20° micro, and about .020" bte. I tested it outdoors, and it passed through brush like nothing. Then I tested quite hard chopping hard wood. That rolled the edge but only in the spots where I applied the most force. I was able to use a rock and fix the rolling in the field. I suspect if I had batoned a nail, I would have irrevocably rolled a half moon out of the edge and had to regrind.
I tested a second time with more hard wood chopping and this time also batoning it through a very knotty piece of wood. The rolling this time was more severe, and I had to reprofile it slightly on the grinder. After that, I left the edge more obtuse, and though it did not roll any more with hard use, it just didn't pass through brush and small branches like it did before. I never tested it on a nail.
Thanks
