Gerber 400 Compact Sport Multi-Plier
First, I would like to thank K man for generously providing the Gerber 400 (along with a SOG PowerLock) for this pass around/ lottery. I would also like to thank Dave H. for running the pass around.
- Gerber 400 Compact Sport Multi-Plier –
– DETAILS -
from Gerber’s site -
http://www.gerberblades.com/products/view.php?model=5500
OUT OF THE BOX – I liked the 400 size better than the larger 600 Pro Scout that I used to have. The 400 is big enough to comfortably fill my hand but not too big or heavy (6.6 oz nominal weight). Like the larger Gerbers, the 400 can be opened with one hand either by depressing the button catches and sliding the pliers out with your thumb and index finger, or by simply flicking it open. I found the handles to be quite comfortable.
All of the tools lock and do not clump, although the pliers need to be extended to get to them and access is somewhat restricted since the handles only open about 60 degrees. Unlocking the tools is easily accomplished by sliding the black plastic (Zytel?) tabs back about 1/8”.
The downside to the 400 compared to the 600 is a reduced load out of tools. With the 400 there is no saw or file. I was also disappointed that the Compact Sport has no awl, rulers or provisions for attaching a lanyard. The 400 is fairly bulky for a “compact” tool when folded (about the same size as a folded Leatherman Wave).
The finish on the 400 is the typical Gerber dull satin gray.
OPERATION – All of the individual tools open without clumping, although a few were a little stiff and/or felt gritty. The spring loaded lock releases work smoothly. The pliers slide in and out of the handles easily but not very smoothly. Once extended, the pliers open and close effortlessly (they are loose enough to swing open and closed by the weight of the handles alone).
LOCK - Gerber uses a spring loaded sliding bolt action type lock. All tools lock automatically and are released by sliding the lock tabs back about 1/8”. This is an excellent lock for a multi-tool (a similar lock is used on the Victorinox SwissTool).
- TOOLS -
PLIERS – The Compact Sport has needle nose type pliers that open about 45 Degrees or 1 7/16” tip to tip. The plier tips are dressed precisely enough to pluck hairs from my arm. The hand filling handles make the pliers comfortable to use and unlike early Gerber multi-tools, there is enough space between the handles when closed to prevent pinching.
WIRE CUTTERS - There is a 5/16” wire cutter section of the pliers. There is no “hard wire” cutting notch. The 400’s wire cutter easily cut 12 gage copper wire, which was the biggest wire that I had on hand.
WIRE CRIMPER – The 400 has a wire crimper much like those used by Leatherman and SOG. I used it to crimp on some 14-16 gage (blue) crimps, and I had some difficulty getting good, tight crimps. I believe the reason is that these connectors are slightly too big for the 400’s crimper and that it is hard to exert enough pressure with the fairly short handles. I would expect the crimper to work better with smaller connectors.
½ SERRATED KNIFE BLADE - The 400’s flat ground drop point knife blade is 2 9/16” long overall, with about 2 ¼” of cutting edge, of which 50% is serrated. Unlike most combo edge blades, there is a conventional bevel on both sides of the plain edged portion of the blade - which is preferable to a chisel edge for most purposes. The blade is about .097” thick at the spine near the base and tapers to about .040” at the tip. The blade is about .030” thick behind the serratations for about a 30 degree edge angle and about .025” behind the plain edge portion for about 12 degrees per side.
I don’t know how much K man used the knife blade, but it appears to be in new condition. The plain edge section is just barely sharp enough to shave and the serrated portion is a bit sharper – this is sharper than the blades on several NIB Gerber tools that I looked at in a store recently.
This blade probably won’t take the place of anyone’s EDC, or impress a knifeknut, but it seems to be a decent choice for a multi-tool of this type.
SCISSORS - I tried the 400’s scissors on string, 550 lb paracord, ¼” flat cotton shoe lace, rubber bands, denim (Wrangler jeans), monofilament fishing line, 32 lb. card board, and phone book paper. The scissors worked well on most of this except that the short (about 5/8”) throat made it slow and snippy on long cuts, particularly on the card board. The 400’s scissors also had problems getting through the hem on the blue jeans, although it eventually gnawed its way through and it sometimes took two tries to get through the paracord.
All considered, the scissors performed reasonably well for their size, but they should be bigger.
BOTTLE OPENER - This is a feature I don’t use very often, but the Gerber bottle opener dose seem to work better on bottles than the combo bottle/can openers that Leatherman uses. There is a 3/16” screw driver combined with the 400’s bottle opener.
CAN OPENER - The Gerber’s can opener cuts towards the tip like the Victorinox can openers, but it is not as smooth or easy to use and leaves more jagged edges on the can/ lid. There is no little screw driver tip on the 400’s can opener.
While this can opener is not ideal if you have a lot of cans to open, it dose serve it’s purpose for occasional use.
SCREW DRIVERS - The Compact Sport has 3 standard screw drivers: a 5/64” (2 mm), a 3/16” (4.8 mm) combined with the bottle opener and a 7/32” (5.8 mm). These work well except that they are all too short (15/16, 1 3/16” and 1” overall, respectively).
When driving screws the tip of the pliers stick out just enough from the handles to jab your hand in some positions, but are otherwise comfortable.
PHILLIPS SCREW DRIVER - The 400’s Phillips seems to have a #1 size head, but much like Leathman’s Phillips, the point is flatter than a standard # 1 Phillips, probably so that it will fit both #1 and #2 screws . Much like the standard drivers, the 400’s Phillips works well, but is too short (15/16” overall).
Although I didn’t have one to try out, Gerber dose offer an optional tool coupler that attaches to the Phillips driver that takes standard ¼” hex bits.
- RUST RESISTANCE -
Towards the end of the week, I noticed that the Compact Sport was developing very small/ faint spots of rust on both the plier jaws and the handles. This was removed by scrubbing with Tri-Flow. I was a little surprised that the 400 was beginning to rust, especially since it was not exposed to anything which I would expect to cause rusting. I was using the 3 other tools (a SOG PowerLock, a SwissTool and a Super Tool 200) at the same time and none of these rusted. I suspect that the Compact Sports slightly rough finish on the plier jaws may have contributed to this.
- CUT TO THE CHASE -
The Gerber multi-tools have a lot going for them: one hand opening pliers, comfortable handles, all locking tools, no clumping etc. Unfortunately, Gerber’s design and selection of the individual tools just doesn’t quite measure up to the competing multi-tools from Leatherman, SOG and Victorinox. To be specific, the Gerber 400 lacks an awl, lanyard attachment ring and rulers. And its screw drivers are all too short.
Although about ¾’s the size of the 600 series Gerbers, the 400 is a fairly bulky multi-tool – a little too bulky for every day pocket carry in my opinion.
Still, the 400 is a good multi-tool - certainly not a bad choice; particularly for someone who uses the pliers much more than they do the other tools.
Thanks again to K man and Dave H. for the incredible pass around/lottery!
- Frank
Nice review Frank k. The sport was one of my first multi-tools and I carried it several weeks till I moved on to other things. I was pretty excited to open the box and put it right to work without reading the directions. For those unfamiliar with the 400, the knife, when being returned to the handle, has a "snap back" feature about 3/4 of the way back into the handle. Naturally, the way I was holding the tool put a finger in the way and the blade sliced it:eek:
I do recall the tool being extremely stiff,especially the pliers which ride in a track in each handle. A little oil and some use, and the plier head will extend and retract holding the tool in one hand. My sport is several years old and rust has not been an issue,however,I tend to baby my multi-tools with oil and polish.As far as being bulky, I'm not going to disagree because that isn't an issue for me,however,the design of the tool does make it broader than Leathermans, for example.
My own feeling on the Compact Sport is that it's ideal for glove compartment,fishing box,survival kit, but only if you normally carry
a multi-tool like the Wave or Swiss Tool.:)
Hi Matches, thanks for the information.
I don’t want to overstate the rust spots – they were very small and faint enough that I had to look hard to see them. I was just a little surprised that the spots were showing up so quickly (a week of handling). I only mentioned it to see if anyone else sees any rust or not. I don’t remember any rust forming on the Pro Scout I had, but I didn’t keep it for long.
I don’t always baby my multi-tools and the Leatherman’s have all shown a bit of rust on the plier heads and sometimes the file or knife blades after I have carried and used them for awhile.
Cliff, the handles are about as comfortable as the Super Tool 200 and SwissTool, but the 400 has much shorter handles, so you don’t have as much leverage. The only thing I didn’t like was that the tip of the pliers sticks out a little when folded and they can be uncomfortable when using the screw drivers, but you can adjust your grip to avoid this. Overall the Gerber handles are more comfortable than the Leatherman PST, SOG PowerLock and Pocket PowerPlier, and much better than the original SuperTool.
- Frank
Nice review frank k. Here's my thoughts after handling it for a week:
I agree that it is a little annoying that the plier heads stick out a little bit in the closed position, and the tools can be slightly difficult to access due to the limited amount the handles open. Its not prohibitive to getting the tools out, though. Over all I found it to be very comfortable in the hand, and I liked the size/weight for carry purposes. I found the scissors to be ridiculously tiny. I can't see using them for cutting anything anything larger than loose threads. They cut small things well, though. I could see purchasing one of these in the future. For the price I think it is a good tool overall.
I had a Gerber 400 a couple years back. Its first real use was on a fishing trip with a buddy. He got a treble hook stuck in his hand while we were pike fishing, and used the Gerber pliers to pull the hook out. He got the hook out, but killed the multitool. The thin frame bent so badly that the pliers wouldn't retract. :barf:
Thanks Eric!
Hey ‘Buzz, how did your bud bend your Gerber? Did he use it to cut the treble hook?
- Frank
He used the pliers to push the barb out through a second hole in has palm, and then used the pliers to flatten the barb to the hook. Once the barb was flattened, the hook easily slipped back out. The handles actually crushed while he was pushing he barb through his palm. It took a ton of leverage. Skin is some tough-@ssed stuff!!!
I know it's a bit late to add anything, but to anyone out there with this tool... have you tried customizing it? I had an old Gerber 600 model, and I replaced one of the tools with a spare house key that I cut to fit in the slot. My 400 has the following: scissors, Phillips #1 screwdriver, non-serrated blade, small/medium/large flathead screwdrivers, and jigsaw. The non-serrated blade and jigsaw came off of another Gerbertool, which basically looked like a small box with built-in flashlight and fold-out tools.
On a side note, I've noticed the rusting as well and am disappointed about it; none of my SAK's have rust!
