Gerber BMF
A little while ago I managed to source this knife from a good friend in the UK. This was the first 'proper' large quality fixed blade I ever saw and I always regreted not having the cash all those years ago and letting it slip by. Well when it was discontinued I was gutted!
My question is this, after giving this knife a good satin hand polished finish, I like it a lot more, anyone else done this with GB finishes?
Secondly anyone actually used this knife in the field? 440a at 54-55 aught to be quite tough?
Thanks.:)
I purchased my first one during the initial year that they were produced and I have been using them since. The sawback is nearly worthless, although I have found it useful for some minor tasks. The blade can take an edge, has excellent stain resistence, and works well enough. Edge holding is so-so but it sharpens up fast enough on a ceramic stick. I really like the sheath and especially the handle on these knives.
It is a good working knife. Like any other knife, it has limitations. The knife, as balanced, is a poor chopper; it has a fragile point (no biggie - but expect to loose about 1/16" when used); and, care should be taken when using it to chop through bone. Although, I have had no problem with the BMF, my LMF chipped badly while trying to chop through bone. Used with reasonable care the knife will serve you well for years.
n2s
Thanks! Its good to know, that while it would not probably be a serious carry (as I have far far better blades) it is not a poor knife.
I am unsure over the handle though, if feels a bit to 'big' in my grip. But perhaps this padding gives a better level of comfort? Have you found you got used to it? Perhaps you have bigger hands than me!:)
I got one back in the 80's when they first came out. The only real disappointment was the handle was useless when it came to bearing down, or chopping. Otherwise i have always liked its looks. The sheath was nice!!!
I used it for a year as a camping knife, but couldnt get over its uselesness as a chopper, so I substituted it for a w-49 (which worked much better as a camper).
The BMF was my first real knife. I have used it to cut, hack, chop and stab everything I could get my hands on. Even the saw got used, mostly for cutting notches in poles for shelters, but occassionaly to cut fire wood into short lengths. Then I split them with the BMF. The steel does not hold it's edge like some others, but it will get you through a few days of use, and sharpening is easy. The shetah is excellent. The handle was a little to big for me, but a black bear chewed on it one night, so I reprofiled it with a file, and it was great. It does offer quite a bit for a knife so overlooked. While it is certainly no Busse, it ain't junk, either. I finally traded mine last week, and I know Terry will enjoy it just as I did.
