Gerber Gator 154cm? Can you tell?
So I purchased a Gerber Gator the other day and was surprised when I noticed
the blade simply says Oregon USA on it. Most of my knives say what type of
blade material is used (e.g., my Spyderco says AUS-8 on the blade). No where
on the box did it say either. The place I bought it from advertised it as 154CM.
I was talking to someone that mentioned some of them are made from a cheaper grade 400-series?
The box was labeled Gerber Gator model 6079. Is there a simle way to determine what type of material
a blade is actually made of? I have tried to get to the gerberblades.com site to check, but have not
had much luck.
Also, the blade edge is ground much more coursly than I am used to, you can see the
grind marks. Is that normal?
Thanks
Also, the blade edge is ground much more coursly than I am used to, you can see the grind marks. Is that normal?
I found the same coarse grind on an E-Z Out Plain Edge that I bought last year. The grind marks were so bad that when I resharpened the blade, parts of it crumbled into little pieces on my stone. My older E-Z Out Combo Edge(bought in about '99) did not have bad grind marks and worked well for me. I don't carry the newer knife and I don't buy Gerber knives any more.
I have heard several stories about a decrease in Gerber quality for their lower cost knives since the Fiskars buyout. I do not know about their higher end knives.
Maybe the grind marks are the new normal for Gerber?:confused:
They should not be normal on any decent blade no matter what the steel.
The Gerber Gator with 154CM is/was Model 6064.
(I dont' know if they still make it in 154CM.)
The 6079 that you have uses 420HC.
