- Nov 6, 2014
I want it for everything a knife can do. Without oiling it.
Are you in the Army and want this knife for jumping out of aircraft, smashing windows and bricks, cutting straps and wire, hammering spikes or nails, and prying stuff open? If so, that's what the LMFII is designed for. And it is bulky to serve the purposes.
If you are NOT in the army and do not intend to relegate this to a 'truck knife', then you may be better served by a lighter, less multi-purpose cutting tool. The Seal Pup Elite is that, as is the Gerber Prodigy and a great many other knives which are all superior to the LMFII for general utility cutting and woodcraft. If you are restricting yourself to only these two knives and your demands do not match the first line, get the SOG. I have the Gerber, i like it alot, but I am not military and the knife doesn't see nearly as much use as others I own. The pommel does work well as a hammer, the blade is thick enough to pry, the serrations do cut rope and other materials with authority and can carve wood, etc., the plain-edge is easy to sharpen, the handle is comfortable and well insulated in cold weather, but it's just so heavy and bulky that it is not my preferred cutting tool when other choices are available. That's my $0.02
The pup is the better choice for all the reasons mentioned above. Plus it is full tang where the gerber is not, purposely, but still not.
They are both rat-tail tangs and the width, thickness, and similar length makes the LMF much stronger. Also the LMF is much wider at the ricasso area and tapers off nicely. The fact that the little Pup has a more proportionate tail to blade ratio than the LMF is not a factor as the pup would break first in a stress test. Again, the tail of the LMF is Wider, thicker and almost as long as seal pup, so it's simple math.
Neither tang would be considered a "rat tail" tang. Think about it, what does a real rat's tail look like? Long and very thin. The tang on the above knives are quite substantial. If you manage to snap the blade at the tang you are doing something very foolish with a cutting tool. Get a pry bar.![]()
