Gerber Spectre review
Just took delivery of a 1st production run plain edge Gerber Spectre (model 06900) yesterday and spent the whole day playing with it like I do all my new knives. I thought some other knife knuts thinking of getting the same knife might want to find out what I learnt, so here goes.
Basic Specs:
3 3/4" blade of 1/8" stock 154CM with a 3 3/8" cutting edge and black Titanium Nitride coating. OAL open is 8", closed 4 1/4". Weighs 3.7 oz and has titanium liners and textured G10 handle scales. Liner lock locking mechanism. Double thumb studs. Attached with a tip down pocket clip secured with 2 screws. Bought mine for $109.
Function:
Slightly rough opening out of the box which smoothed up a little after several dozen cycles and re-lubing, but still a bit tight. Locked up tight with no blade play up/down or sideways. Blade was reasonably sharp out of the box and could shave hair with some pressure. A little work with the Spydie Sharpmaker 204 made it cut better.
Closed, the blade was nicely centered between the liners. Some movement of the blade in closed position, resulting in the blade hitting the backspacer if closed quickly. Looks like the hole in the blade is is not aligned properly with the detent ball on the liner. On mine, the blade cut a shallow groove in the plastic after several closing attempts. Didn't seem to have damaged the edge but will probably dull the blade with time.
Testing:
Like all my other new knives, I tested it on some cardboard boxes which I have around in plentiful supply. After destroying some 7 or 8 boxes, I found the edge still sharp enough to shave hair though not hair-popping sharp like before I started.
The liner cutout does a pretty good job of preventing my fingers from sliding forward even when I did some forceful stabs and cuts. The design of the handle is comfortable and works well with the saber grip with the thumb atop the blade spine. I tried disloging the lock by stabbing the boxes and twisting the blade out and the lock held. Also did some spine whacks of increasing force which the knife passed.
The Ti-Nitride coating seems to be pretty tough. I tried scratching it with a nail in a out of the way spot and had to work at it to mark the material. One funny thing, the titanium liners seem to be coated with a grey-brown material that looks like rust at first sight. Doesn't affect the function, though, just looks a bit strange.
Conclusion:
Seems to be a well made, well thought out design. A nice size for everyday carry if not for the hardcore tactical look that may raise a few eyebrows. Problem with the blade blade hitting the backspacer due to the misalignment of the detent ball. The liner cutout could be scalloped slightly to make opening easier. Other than that, I think most knife knuts will be satisfied with it.
Andrew Limsk
"Praise not the day until evening has come;a sword until it is tried; ice until it has been crossed; beer until it has been drunk" - Viking proverb
[This message has been edited by redvenom (edited 01-27-2001).]
Man....you sure gave it a little workout there Red!
Knives & Things
Mike Payne
At the place where I work, I think they have taken to calling me the box-killer due to my fondness of trying out my new knives on cardboard packing boxes.
Andrew
The Gerber Spectre I saw at the SHOT SHOW was a good example of what manufacturers are capable of producing today. Very good materials and construction at a great price point. This knife in particular seems to offer a level of quality I don't normally associate with Gerber.
Stay Sharp,
Sid
Andrew,
Thanks for sharing your impressions!
What kind of grind the blade has? Looking on GERBER pics I can't consider is it sabre or hollow one. My GERBER Yari has pretty high grind but I should use ruler to check is it flat or lightly hollow like CRKT Point Guard.
Some movement of the blade in closed position, resulting in the blade hitting the backspacer if closed quickly...
I've noticed this on the Gerber SLG 3.25, too. Although in this case, it's metal on metal = dulling faster on the contact point.
<font face="Verdana, Arial" size="2">Originally posted by Sergiusz Mitin:
Andrew,
</font>
Sergiusz,
Went back home and took a closer look at the Spectre blade. The main bevel seems to be a hollow grind (very shallow, almost flat) with a false edge on the top running for 1/3rd of the blade from the tip (saber style). I don't have a digital camera or a scanner or i'd post some pics of the knife.
<Rant Mode On> Yeah, Gerber what is this with the arty-farty angles? Wish they would just photograph their knives sideways like everybody else so we can actually see what they look like
Andrew Limsk
Hi Andrew:
I just recently got a Gerber Airframe (actually 2 of them) and found that, like your Spectre, the blade cuts into the plastic spacer. I posted about this and a couple of respondents told me that their knives did not have this problem. Since you have had your knife longer and since the blades are, I believe, very similar I was wondering if you had any additional info on this problem.
Did you come up with a solution? Does the blade dull a lot quicker? etc.
I am thinking about getting the Spectre as well and anything else you have found out about the knife would be usefull. From your experience (which has gotta be much greater then mine since I have just been bitten with the collection bug) do you like the knife and would you recomend it?
Thanks
If you really like the knife and intend on keeping it, try using a dremel tool to grind out where the blade is touching the spacer.
Yes, I would recommend this knife.
For me, it's a well made, well designed knife and best of all, a perfect size for daily carry. The handle is slim enough to ride comfortably clipped to the pants pocket. I really like this knife - though you may want to handle one first to check out the blade hitting the spacer problem. Might just be my knife that has this problem.
Funny, though. I've been carrying the blade around for a couple of weeks already and despite cutting a groove in the plastic, it doesn't seemed to have dulled the blade much. By comparison, my CRKT mirage which has this problem developed a roll along the edge. Guess 154CM is much harder stuff.
I've superglued a thin piece of rubber sheet to the spacer which cushions the blade and solves the problem of dulling somewhat after reading your post about the Gerber Airframe (thanks!). I was also gonna try sanding or shaving the spacer a little - don't have a dremel tool, unfortunately. I might just try you idea about wrapping some material around the stop pin.
Red
[This message has been edited by redvenom (edited 02-21-2001).]
<font face="Verdana, Arial" size="2">Originally posted by redvenom:
...I might just try you idea about wrapping some material around the stop pin.
Red
</font>
Red:
I rethought that (my reply to myself in the other thread) and decided it would not work. At least not on the Airframe since the same post is used as a rest for the closed and locked (open) positions. Wrapping anything around the whole post would prevent it from locking.
However, as I mentioned in the other thread (in response to your post), I did place a piece of sticky backed felt on the blade itself where it contacts the post and this keeps the blade off the spacer. I have no idea how long this solution will hold up and I am awaiting the return of my knife from Gerber (they asked me to send it in) before I go any further.
It also occurd to me that with some specialized form of epoxy you might be able to build up the blade at that point so that it holds the edge off the spacer. Since this is not a high stress application it might work.
BTW: If you like Gerber knives here is a web site with really great prices:
http://www.wholesalehunter.com
I got my Airframe from them for $108 and they carry the Walker (International model) for $57 (about $40 less then anywhere else I have found). They are also going to be carrying the Spectre although it is not on their site yet. The usual disclaimers about any personal connection with the company apply...
Red:
After I posted last time I noticed that you live/come from Malaysia. I have no idea if the site I mentioned ships overseas.
