Hi Jimbo,
My last few flint rod/metal matches came from Campers' Village in Calgary (one in Edmonton as well), they cater to the usual high-tech/backpacker crowd w/ a bit of bush living types as well (wood stoves, wall tents, etc.). The website is
http://www.campers-village.com/general.html
However I couldn't find the metal matches on the site so you'll need to Email & ask. The 2 types available recently were both plain zirconium rods w/ a sturdy flat plastic handle on one end w/ a hole. The smaller one is about 5cm of rod w/ a blue tab & a cord-attached scraping blade; the larger one is about 8cm of THICK rod w/ a black tab w/ no scraper - I believe both retailed under $20
I don't believe I'm confused - the
Strike Force is larger, rectangular & black or orange; the Blast Match is more compact, rounded, & spring loaded for one-hand use - correct? I've used the Strike Force & discarded its value for my needs/skills - sorry, I was only (worst-case) projecting the potential durability of the casing.
Had to look this one up
"Inonotus obliquus" or Clinker Polypore, I believe this sometimes referred to as True Tinder Fungus. It's never very common (damn), shows up on mature, living paper birch, rarely on aspen; hard to find around the Calgary-west foothills/mountain areas, but more common in the true boreal areas past Rocky Mtn House, Edmonton, etc.
More common is the (False) Tinder or Hoof Fungus, Fomes fomentarius, which appears on birch, aspen, large willow & hawthorn, etc.. If you have Northern Bushcraft, it covers processing into tinder - if not, ask away...
Regards, Dudley
