I currently have an EdgePro. It works well and does what it's supposed to. The more I get into sharpening the more I see value of it's simplicity and also the limitations. Not having a clamp is gives a lot more flexibility and also makes it challenging for some blade grinds. More challenging to get a specific angle.
Do clamped systems work well with all blade grinds? Do they align the blade edge at 90 degrees to the vertical post of the sharpener, or does it vary with the blade shape?
I see 4 options for clamped sharpeners: Wicked Edge, KME, TSProf, and ViperSharp. I'm not considering the Lansky.
- Wicked edge: Looks good, seems solid, appears to set angles easily. Expensive, esp for additional stones.
- KME: Well regarded. There seem to be a lot of complaints about the clamp.
- TSProf: Also looks good. Can get expensive. It seems to have a nice protractor attachment. Does that work as well as it should? And why to they also sell angle cubes if the protractor works? This uses EP stones, which is a big plus since I have an EP.
- ViperSharp: Newer and not much info. Saw one at the show. Looks good. Not sure if there's any advantage over the KME.
