On my knives, I usually grind a "modified tanto point" on them. Basically, this consists of simply grinding the point, replacing it with a short blade at the end approximately 45 to 60 degrees to the main blade.
This strengthens the tip a bit and gives you two points instead of one plus a small extra blade. In most cases, this extra blade would only be 1/16" to 1/8" long.
Also, I usually make this little extra blade a bit more obtuse than the main blade. It takes only a few minutes with a medium or coarse diamond stone to do, or you can do it in seconds on a belt sander.
Obviously, for those who are collectors it wouldn't be a good idea, but for people who use their knives it works as well as a conventional point for most tasks and better for many tasks.
I got the idea from Dr. Ed Ashby's studies on broadhead lethality on large game such as buffalo. He found that such a tip on a broadhead penetrates better than a conventional pointed tip and is less likely to break or bend on impact.
I should add that it would be perfect for those who complain that some blades are slightly longer than the legal carry limit. It does shorten the blade by a tiny bit.
Don Clark
