Hashishiin
- Dec 29, 2021
keep Wave as is and add the plainedge 420HC blade to where the scissors are on the Wingman?
Okay, as stated, I have an S30V main blade Leatherman Wave+ inbound plus the original blade in a case. I suppose it is already a Leatherface because of the swapped blade. I was always thinking about adding an upgraded blade to my Wingman, but now I have an upgraded Leatherman... But I am attached to the Wingman because I love the spring-loaded pliers so much, and the spring fell out of my scissors, so I wanted to replace that with a blade, which I can now, having a PE 420HC Wave blade, but I may need to file down the lock so it fits, I heard. Can I do that with sandpaper? I am not used to filing metal. I do actually like the half-serrated blade on my Wingman. Maybe I should just wait and slap a 154CM blade where the scissors are on that, might fit better...
I am debating what to do for my main multi-tool. I do not mind the weight of the Wave, it's only an oz heavier than a Wingman, as long as it has a pocket clip, I'm fine to carry it, like I said, I will just miss my spring-pliers. If I end up carrying the Wave, which seems likely at this point... how are the pliers? How are they without the spring assist? Someone make me feel better about potentially giving up my trusty Wingman for every day carry...
Also, I assume the scissors on the Wave are replaceable with an original Wave blade? I am getting the original PE 420HC blade as well, and since I carry a SD Classic, and those scissors are tight, I don't need no Leatherman scissors. So, I'm thinking about taking those off, and putting that blade in, to have three blades, a PE and SE 420HC and S30V no scissors. That, at least, doable, I assume?
What would really be a dream is to get a 154CM blade to replace these scissors with on the Wave, having three steels on my Leatherman
That just tickles the nerd in me, man. If you want to make that a reality, I will buy your 154CM blade, trade you a 420 blade, some 420, whatever you want for that sweet sweet 154CM LOL
