- Aug 26, 2013
I have been trying to HT with my small forge and I wanted to be as accurate as possible so I got a temp sensing setup from Auber Ins(kiln thermometer, type k thermocouple, ceramic sheath etc) and got it all set up today and started testing it out. The problem I have is that I can't keep the temp in the forge below 1650-1700F and all of my current steel is 01 and 1084 so I need lower temps. I can make the 1084 work for now but can't get low enough for a soak with the 01. If I try to turn down the burner any lower to decrease the temperature the burner sputters and goes out. I figure I have a few options but wanted to see if anyone had any suggestions since I have very little experience with any of this:
-increase the size of the openings on the front and back of my forge to release more heat and decrease the temp. I think if I did this I'd still have a hot spot in the middle and cool spots near the front and back.
-Build a bigger forge for the same burner. I really don't want to do this at this time as I have a long list of other gear/equipment I need to get.
-Get a different burner. Don't want to do that b/c that may be the only decent part of my forge since I didn't make it. I'm using one of Zaph's Atlas 30k burner w/0-20 psi regulator sets. As the product description says I can get it "hot enough to forge weld" but unfortunately not cool enough to heat treat.
-Figure out if it's possible to decrease the output from this burner so the current setup will work and produce lower temps. Obviously this would be ideal and why I'm posting this here to find out if there's a simple way to do this that I haven't thought of. Anyone have recommendations on how I might be able to do this?
Here is my forge setup:
Housing- 12" long 6" diameter stove pipe
Insulated with 1" thick Inswool with satanite coating. I believe it has 1 layer of 1' thick Inswool all the way around and then another piece on the bottom to form the floor. Inside diameter of the forge is about 3.5" vertical and 4" horizontal. About 130 cubic inches volume.
Front entrance of the forge is 2.5"x2.5". Back opening is 1.5" x 2.5".
Ultimately I need a better forge and a HT oven but for now if anyone has any suggestions on how I can make what I have work better and get lower temps in the forge I would appreciate it.
-Aaron
-Aaron
