- Dec 26, 2010
How high a grit do you have to go to get a mirrored edge? And can you do it by hand?
Visible light has a wavelength of around 0.4 to 0.7 microns. Once the scratch pattern gets smaller than the wavelength of visible light, it will look optically smooth and like a mirror.
I suspect that grit particles make scratches significantly smaller than their diameter, especially for stropping. So stropping with compounds somewhere around 1 micron sounds about right.
In my (limited) experience, I'm going to around 2k on stones/sandpaper, then stropping with 0.5 micron and 0.25 micron diamond. This isn't an ideal progression (big jump between 2k grit and 0.5 micron), but it does manage to get me a mirrored edge.
Sincerely,
--Lagrangian
"What grit sharpens the mind?"--Zen Sharpening Koan
I use a Spyderco Tri-Angle sharpener, finish with their fine ceramic rods, and strop with an old leather belt (no abrasive added), and I easily get a mirror finish--hair popping sharp.
what people call mirrored edge is as subjective as how sharp an edge is.
and this perception can change depending on bevel width. on a very short bevel fine sharpmaker rods plus bare leather can look shiny, put the same finish on a scandi knife and you'll see way more scratches even if you make sure to erase all the scratches.
when i refinish my carbon steel kitchen knives i usually go to 600 wetordry plus some polishing compound on a rag. i can see mysellf in the blade. but i also can an obvious scratch pattern ... is that a mirror finish ?
i consider mirror an edge where i can't see scratches anymore, i'd call it good if i can see a faint scratch pattern when playing with the light like straight from my 10k SS. this won't happen with just the fine rods and bare leather.
Just the fine rods put a pretty nice finish on the bevel face, but the leather makes it pretty darn shiny without noticeable scratches, but it may be just shy of an actual "mirror" finish--I haven't done any reflectivity tests. : )
Also, I said I don't add abrasive to the belt, which is true, but it does load up some with steel particles over time.
