- Dec 5, 2009
Hey guys. After buying my BK9 and falling head first into the BeckerWorld, I did countless hours of searching and looking at pictures of customized knives. The one thing that I noticed was that most of the knives pictured have the roll-stamp for the logos, which, after removing the coating, remain on the blade and in my opinion look great. I had only seen a couple of pictures that showed a stripped blade and the faint laser etching that remained.
I did a google search and found that some of you guys were using multiple runs of Ferric Chloride to etch the logo deeper. So I bought some and tried it but I just wasn't seeing the logo get much deeper. Of course, I couldn't expect the depth of a stamp, but I wanted it deep enough to not lose it over the years.
So, I decided to build a quick electro-chemical etcher. Using a AC/DC power adapter I attached an alligator clip to each wire then attached the POSITIVE wire to the blade. The NEGATIVE clip holds a QTip close to the end. This is your etcher. Make up a solution of salt water, as much salt as you can get to dissolve. Dip the Qtip in the water then onto a piece of paper to remove most of the excess. Now, press the tip to the laser etched logo and work it back and forth. You will see bubbles and hear a hissing sound as the steel is burned away also creating steam. If the hissing stops, rewet your etcher tip. After a bit you will have to discard the qtip and get another due to black buildup. Just keep working at it evenly. You can also clean the spots after a couple rounds with soap, water and a toothbrush. This removes any carbon residue and allows for a better connection.
Alternately, you can finalize the etch by getting an AC transformer and hitting it again. The AC voltage will blacken the etching provided by the DC voltage.
Here are mine after I stripped off the coating after etching:
It's deep enough I can easily catch my fingernail in it.
Hope this works for you guys, if you have any questions I'll try my best to answer!
