Gifted To Me
Boy!! These forums blow me away. Sooooo much information. I'm not sure if these are acceptable / permissible traditional knives or not since I'm not a serious collector but that were gifted to me. Most have a few spots of corrosion and I like to "restore" the worthy ones as much as possible. I am unsure what is the best method to remove the corrosion and stain left as a result. Any pointers would be greatly appreciated. Oh yea, I would like to know the approximate production years as well. I hope this isn't to much to ask. Many Thanks.
The Buck:
Send to Buck for a SPA service. I think it is under $10 plus shipping. It will look new when you get it back. (the initials(?) and date in the bolster will still be there, depending on how deep it is.)
Using the SPA service does not void the lifetime warranty.
It looks like there is a date of 2000 on the bolster?
If so, it should have the "Edge 2000" blade geometry. MUCH better than what they used before.
Boker and the Camillus:
Both have a lovely patina (prevents rust)
Personally, I'd just sharpen them. They don't look like they need anything else.
If the action is gritty, wash with warm water, hitting the joints with a toothbrush, and working the blades under running warm water. Dry, (spraying the joints with WD-40 will drive out any moisture, or use compressed air if avalable) then oil the joints. Note that WD-40 is not a lubricant. Adding adropper two of whatever oil on each joint is no biggie. Should be oiled at least monthly, anyways.😇
For the lube, over the decades I've used at one time or another: 3 in One, Transmission Fluid and engine oil (fresh or used, "natural" abd synthetic), mineral oil, olive oil, hydrolic fluid, Hoppy's Number 9 (what I'm currentlly using) or other "gun oil", 2 stroke oil, and even cutting and honing/sharpening oil. Basically, whatever I had available.
Many wlll tell you: "Use a food safe oil like mineral oil if you'll be using the knife on food or cleaning/butcheriing critters and fish."
Personally, I never bothered. There isn't enough left on the knife to worry about after you wipe it down. NONE of the oils I've used over the last 63 years changed to taste of my food, nor made me sick.
I like a keen edge. Over 60 years I've found 10 degrees per side (20 degrees inclusive) works great for the "simple" carbon steels these have (10xx, most likely 1095), and the 440A/440B/440C and 420/425 stainless steels. Once the edge is set, stropping restores the working edge 8.5~9 out of 10 times.
Edgemaster:
Automatic/"switchblade? ... does it work? If not, someonein the Automatic/Switchblade sub forum might know how to fixit. (and where to get parts)
There is some rust or grime it looks like near the tang.
scrub with oiled 0000 steel wool to remove the rust. Mineral Oil, or 3 in One Sewing Machine Oil will work fine.
For anything else ... the Auto/Switch Blade sub forum would be my suggestion.
What are the handle slabs/covers? I can't tell if plastic or if painted or anodized metal.
The KaBar:
I don't see any issues on it. It isn't really dirty.
You could hit the sheath with Saddle Soap and mink oil if it is stiff.
As for the leather washer handle, I don't see any excess dirt or anything.
I'd sharpen and use it.
DON'T store the knife long term in the sheath! That may cause rust, and turn the guard and pommel green, depending on how humid it is.
If there is rust on the Boker and Camillus that I didn't see in the photos, oiled 0000 steel wool will remove the rust and grime, but not the patina.
The Buck was made in 1999. It has that date code on the blade. I would work some glue into that crack on the scale, and clamp it, before that corner breaks off and you loose the piece. Super glue would work, or some waterproof wood glue. With super glue you could just hold it till it dried, but there is a risk of gluing yourself to the knife, so I would use a plastic spring clamp.
O.B.
The Buck:
Personally, I'd just sharpen them. Theydon't look like they needanything else.
If the action is gritty, wash with warm water, hitting the joints with a toothbrush,and working the blades under running warm water.Dry, and oil the joints.
I like a keen edge. Over 60 years I've found 10 degreesperside (20 degrees inclusive) works great for the s'imple" carbons steels these have, and the 440A/440b/440C and 425 stainless steels. Once the edge is set, stropping restores the working edge 8.5 out of10 times.
Edgemaster:
Automatic/"switchblade? ... does it work? If not, someonein the Atomatic sub forum might know how to fixit.
There is some rust, it looks like near the tang.
scrub with 0000 steel wool to remove the rust. Mineral Oil or 3 in One Sewing Machine Oil will work fine.
For anything else ... theAuto/Switchbladesub forum would bemy suggestion.
The KaBar:
I don't see any issues on it.It isn't really dirty.
Asfor the leather washer handle, I don't see any excess dirt or anything.
I'd sharpen it. DON'T store the knife long term in the sheath! That can cause rust, and turn the guard and hilt green, depending on how humid it is..
Many thanks for your help & suggestions. Yes, the switchblade does work as designed. I will put that one on the Auto/Switchblade forum. The only real reason that I include it was that is was made in the USA and not some third world country. The initials are my friends late husbands. Thanks again.
O.B.
Many thanks. I will give some water proof wood glue a shot. I've never had any real success with any type of "Super Glue".
No problem. Switchblades/Automatics are "traditional" knives. They been in production since the 1800's.
They are not tallked about much in this Sub-Forum because there is a Sub-Forum dedicated to them. Sorta like how traditionals are not mentioned much over in the General Form. 😊
BTW, Welcome to BF, and "The Porch" (nick-name of the traditional sub forum) Hope you stick around a good long while. 😁👍
