Well it's time for me to hold a giveaway for a knife I recently purchased and reviewed.
ENLAN EL-02B
I have modified it considerably.
* Grinding a flat surface (sloppy work) so you can use a large flat head to loosen or tighten the pivot.
* Chamfered thenbuffed the axis-style lock buttons to reduce sharpness.
* Removed one spring from the axis-style lock to lessen tension needed.
* Reprofiled the edge to 20 degrees~.
There is some side to side blade play, and a tiny nick on the edge.
The give away is simple, post here once and I will pick out a winner on March 4th at random.
I had to push the contest to close earlier so the knife could be shipped in the same week.
The Winner is poster #68, Moxy.
I sent an email.
ENLAN EL-02B
I sent an email.
