Sando
Knife Maker
- Jul 4, 2002
(Disclaimer: this thread isn't to promote or slam any particular adhesive. Also I'm gonna use the word glue a lot. Epoxy is too specific and adhesive is too much typing.)
OK I'm worried about the glues we use on knives. The more I learn about what's out there the more a "this is the one to use" solution is getting silly.
I'm gearing up to run some tests, but I'd like to present some thoughts for feedback. How should I test, what kind of testing have you done, etc.
Purpose
I think there are 2 basic purposes for glue in knife making.
1. To keep the parts together
2. To seal and protect parts.
For example, if you are using hidden or straight pins, then the glue has to hold the parts together forever and ever. However, if you are peening or screwing them, then you only need something to seal the parts.
Filling vs. bonding
The next issue is adhesion vs. filling. These are two different roles and require very different characteristics!
1. For adhesion you want the parts as close together as possible so no glue line shows. (like between scales and tang.)
2. For filling you want gaps to get filled with something that won't shrink or expand while it sets and becomes it's own material. (like filling the hole in a hidden tang knife.) Adhesion is still important, but gap filling is more so.
Like and unlike materials
The next issue is materials
1. Glueing likeminded materials together. At least ones that stick to the same stuff and expand and contract together. For example steel on steel. Or steel on brass. Or wood and wood
2. Glueing unlike materials together. Things that expand and contract at different rates.
Environment
The final subject is environmental and applies to everything. Does it breakdown, loose it's bond, or become brittle with the following?
1. Heat
2. Solvents (water, hand oils, deer blood, ....)
3. Time
Another interesting issus here is, if you heat it it might lose it's stick. But when it cools down will it be sticky again? Some glues do, some don't.
That's enough to set the stage.
Steve
Purpose
Filling vs. bonding
Environment
1. Heat
3. Time
Steve
