Glue?
I need some glue to stick sand paper to a granite block for but it has to lay dead flat, no bubbles like you get with that spray on 3M adhesive. Anyone have any ideas or tips? thanks!
rubber cement, it cleans a lot easier than super glue. it what i use to put grafphite cloth on the palten.
I think you just answered your own question.
The 3M spray adhesive is what works for me on a variety of projects.
If you are getting bubbles from the 3M adhesive you are putting it on too thick. For your purpose a very light dusting to both items is all that is needed. After it is dry to the touch run a clean hand over it to make sure that it is all laid down. After the parts are together you can roll the paper down with a cheap "J" roller. You will not have any bumps.
Or, you can just give John a call at Tru-Grit and order the special adhesive they have that is made for the job.:p
