Gluing Edge Pro stone to mount.
Does anyone know what would be a good adhesive to glue the stone to the aluminum mount?
I had my 220 stone come away from the mount.
Any help would be great, thanks.
Cheers.
f77 spray adhesive works well from 3m . Do it in a well ventilated area. It is not good to inhale it or have your eyes or other membranes exposed to it. It's what I use and I've glued a few thousand stones by now :) About $15-20 per can. sometimes you can get the small cans.
Ken
Acraglass works really well. You can also use any 2 part epoxy, JB Weld is good. Same thing happened to me and I stopped soaking the stones in water.
I just glued some Mold Master Stones to G10 using Crazy Glue Gel. If the Aluminum is rough surfaced I bet it would work fine there too.
3M 77 spray has worked for me, and I've never had one come off due to soaking. (And I've walked off and left mine soaking for days).
Just make sure to spray both the stone and the blank, and let them sit a minute or two, before putting them together. I then let them sit overnight, although I'm not sure that's necessary. But they hold! :)
