Goddard's Goop?
Do any of you folks use Goddard's Goop as a quenchant?
If so, why?
If not, why?
Thanks!!
I use it quite often....that as well as Tough Quench.
I have had excellent results with the goop quench and the best part about it is that it solidifies between uses so the chance of knocking it over in the shop is greatly diminished.
On steels that get a multiple quench I know use the goop as a 2nd quench so i can stay more consistent in the temp of my quench.....trying to stay at 140f
I use it once in a while. I have it in a 3 qt. container so I only use it for small blade and if I am just doing one or two. Easyer to store too. :D
I'm pretty sure on smaller blades Wayne doen't bother warming it up but he does on larger ones. If you don't have all the ingredence that Wayne uses Crisco's an easy substitute. The one bad thing about straight Crisco is rodents really like it. Keep it covered or mix in alittle axel grease so it don't taste so good.
Isn't it lard, wax and ATF??? I keep it coverd never had rats in it. Maybe the Ole Injun should use it for treerat bait. HEHEHEHE!!!!
George, you want to attract tree rats, just cut the head off a big nail and stick it in a tree, then shove a cob of corn on it and sit back and watch. The little buggers love corn on the cob and will eat it bare, if you let em, hehehehe! :D
Got to e mail that to John (Ole Injun) The way he shoots he needs all the help he can get. :rolleyes: :rolleyes: He should of stuck with the bow and arrows. HEHEHEHEHE!!!! :p :p
IG, you rascal! Those tree rats are better than those bottom feeders you toss in a hot pot of water and whatever! In case everyone here doesn't already know, IG is the ORIGINAL OFFICIAL rascal here!
HEHEHEHE!!!!!
