So I think I am finally going to order some DMT stones. I see they make a bunch of them from big bench stones to folding pocket stones.
First order of business - stone flattening. I have an Edge Pro Apex and would like to flatten the stones. Since they aren't very big I don't need a huge plate to flatten them. Any idea on size? Also - what grit? My idea is to double-purpose the "flattening" stone as a stock remover when I need it, but I'd rather not have too coarse of a stone. I haven't used diamonds aside from "polishing" with 6, 3, and 1 micron sizes (diamond grit glued to glass blanks, got them from chefknivestogo.com a couple years ago and see they don't have them now, at least I couldn't find them to link to), so I am a bit unfamiliar with the "cutting" speed, but hear they do cut fast = may not need as coarse of grit? Give me some pointers and I'll see where the discussion goes.
Secondly - sharpening. I like the pocket sharpeners and folding sharpeners. I like to backpack, and do a lot of general traveling, so the folding sharpeners look like they would be a small/light option. Being double sided also is a plus. My camp knives are generally 1095 and I touch them up between 600 and 1000 grit, then polish on a paper wheel if I have to go that far. Otherwise, a quick run on the paper wheel is all I need and is quick/easy. I'd like to have something in the field with me that I can use to touch up the edges, or to do a quick repair of a more harshly damaged (chipped) edge (that may be a loaded term). Would a "fine" (their 600) grit be coarse enough? If so I'm looking at a "fine/extra fine" double sided. If the "fine" stones cut, based on pressure, and I can achieve at least the cutting ability of my 320 stone with more pressure and finish of the 600 with lighter pressure that would be exactly what I want. I am also looking at the 4" stone "kit" - extra coarse, coarse, fine, and extra fine in one pouch. That might be a good "travel" kit, then leave the double-sided pocket stone for the backpack.
On a side note - I have a Leatherman tool with a diamond file. Going back to blade repair if need-be, from what I have heard the diamond file on these tools is still quite "coarse". Throwing that in to the mix it may work for damaged blade repair in the field, then the regular sharpening could pick up with the DMT "fine" side, and refine on the "extra fine".
