Hey Bladeforums, thinking about picking up a Chinook 4, just wondering how Spyderco's S30V out of Japan compares to that from Golden, Colorado.
Also any feedback from Chinook owners would be great
I don’t think H1 would contain any nitrides in its typical form as used for knives. But regardless, the composition testing involves combustion of the material so it doesn’t matter.Wouldn't the Nitrogen that's in H1 be used for and transformed into Nitrides, thus causing it to not show up in scans in any meaningful quantity?
A carbon steel is not necessarily any less likely to form nitrides.Whereas in a Carbon steel, because the Nitrogen is not being transformed into Nitrides, still shows up in scans as Nitrogen?
Hence why there is 0.05% in the steel.Nitrogen is all around us and is hard to keep out of anything.
The compositions are given in weight percent. Rather than think about “the weight of the gas” you want to think about the weight of the atom, ie molar mass. Both carbon and nitrogen are light elements which is why you only need 0.6% carbon to make a steel well over 60 Rc. Nitrogen has a similar effect to carbon. A 0.05% carbon or nitrogen steel would be quite low in knife steel terms.Also, aren't those percentages based on the physical weight contribution of the element within the alloy? In which case, because we're talking about Nitrogen, something like 0.05 or 0.1 percent, is actually a lot. This is the physical weight of a gas, relative to the weight of metal within the alloy.
Open-mindedness.Am I missing something?
Open-mindedness.
This is the whole reason I've joined this forum. To learn. I appreciate your contribution to the conversation.
If the dynamics of nitrogen content in a steel made a meaningful difference in performance to the end user, why is it not specifically quantified and marketed?
I'm interested in and own different steels and want to know how and why they have the various properties that they do.
There is a difference between quantifying and marketing. The steel company may quantify many attributes of a steel that are not marketed. They may not market them for many reasons, including: 1) they think the information is not valuable to the customer, 2) they think the customer does not want the information, 3) the information is a trade secret, etc. The S30V does not list any Mn or Si even though there is 0.5% of each in the steel. That is common among many of the Crucible steel datasheets. At the time of the release of S30V, being a "nitrogen steel" was not a marketable attribute in the same way it is right now. I don't know if they were also trying to keep the nitrogen addition secret to some extent.If the dynamics of nitrogen content in a steel made a meaningful difference in performance to the end user, why is it not specifically quantified and marketed?
Well Larrin, I appreciate your info. I've read many of your writings on this site and others, and I definitely do appreciate the knowledge you share.
I'm sure you can understand my frustration with the subject when the manufacturer doesn't even properly list what's in the steel.
All of this only reinforces my belief that the knife industry should kick S30V to the curb in favor newer and better EDC steels. Every aspect of S30V appears to be a relative PITA.
