Thanks. The plate is not connected. It is heavy. Right now it is at my friends’ house. Her husband got it years ago and has been trying to get me to take it.Some questions:
What are the dimensions and weight of that piece?
Is that flange/plate attached to the rail or just leaning behind it?
As Andy said, if the end is large enough, setting it upright and using the end as a post anvil gives the most mass under the hammer and blade. You might even cut off a section of that plate and weld it on the end to get a rectangular flat area.
The other option is to mill the top flat and use it as a long thin anvil. You should take the last three or four inches (75-100mm) of the rail and round that section to use for drawing steel out in forging. If the metal plate in the photo is a separate piece, welding it to the bottom of the rail will add mass and stability.
