While all three are good ...and all are good smiths as well. Jim's book is a far broader read. He has three books by the way. But he covers multiple steels, forging, grinding, tempering, patterning- the list is too long. His series of books go from the basics to advanced. For best overal material coverage he wins.
Wayne is a man of the highest calibur with a profound personal knowledge of smithing AND grinding with a plethera of steels. There are not many of us who have used all, most or even just many- of the steels available and spent the money and time to learn to use them.
Ed is newer to the game. And for the most most part has less experience in the broader field. But make no mistake he does what he does very well. The complexity of Eds hardening/tempering is due to the fact that he uses 52100. It is a very exacting steel to get the most out of. Once done it is great stuff. Ed has spent considerable time researching his methods to get the best resutls from this finniky steel. Ed differentially tempers in oil by the way-it is part of his process. He does it by rolling the blade edge in oil. It makes an all together blah temper line not a hamon.
Hamon
The activities that one would deisre in a hamon can only be brought out by quenching in water not oil. It is the rapidity of the quench that that makes the hard transition zone lock in, Thus preservng the delicate granular structure you strived for. Oils make an obscure, diffuse temper line due to the slow transformation rate at which the the martensite forms.
Done correctly the former is only a cosmetic improvement over the later anyway but I love the look-there is no mechanical or performance improvement to be had. Once you know them they become rather addicting so an oil temperline just doesn't cut it anymore. It only a trade thang though-most would not care.
For interest I should mention that steel requires soaking at temperature. Then a full and rapid quench. The immersion brings about a full martensitic transformation in the entire thickness of the blade. The result of the soak and the full quench brings about a uniform grain structure and an even transformation, without surface hardening (this reveals itself in time as the hard edge is sharpened over the years), soft spots and potential cracking and blade failure. A normalizing soak is done by many smiths. In fact most do two or three prior to hardening. This procedure ensures a small uniform grain, providing the forging and temp control was done correctly.
Cheers
Dan
