Good first time Folding Knives?
Hi,
I've been looking for a reasonably small folding knife. Do you guys have any favorites/recommendations for a beginner?
Edit: Sorry, I wasn't specific enough in my question. I'm looking to easily carry it in my front pocket. My budget's under 50 if possible. I'm in California, so subject to the California knife laws.
I hand out Kershaw OSO Sweets to family and friends who are looking for a decent folding knife to start out with.
Kershaw knives.
There are many models to start with.
When you say small, do you mean blade length?
I agree with the recommendations stated by the other posters.
Spyderco Delica
Kershaw Dividend
Cold Steel Mini Recon 1
Any Swiss Army knife
Case Sodbuster (small) or Stockman
Good luck in your search! Sometimes a lot of the enjoyment of this hobby is the hunt!
If you want even cheaper, go with a RAT2!
But again, if you had read a bit here in General, you should know by now that in order to get appropiate answers, you need to make the question the right way. This includes telling us about: budget, intended use, any law constrains, materials, etc.
Try again.
Do you have a price range in mind? For a FIRST folder, while I’d love to suggest a Spyderco Delica, I know many people who are new to knives can’t see spending $70 on a knife.
Kabar Dozier lockback in lieu of the Rat 2
Alox Cadet
Kershaw Blur
Spyderco Delica
Benchmade full size grip or mini grip
^ these are pretty standard gateway knives that knife nutters should try and who probably have owned at one point or another or still do.
There are a lot of good knives out there, too many to suggest. So I'm going to list brands your safe with more or less, this is not a complete list as there are others out there and it's in no particular order.
Opinel (#6 or higher have a lock)
Buck, go American made so you have the 420hc Bos heat treatment which is good or their higher end steel
Spyderco, any of their knives are good though if you avoid the Bug line you get a good introduction of a better steel than your probably used too. If you find a knife you like they make but it seems pricey try to see if they have a comparable one in their Byrd line.
Kershaw, same thing as Spyderco your pretty safe with any of the.. Avoid the starter series and for the most part you end up with a superior steel than your used too.
Rough Rider, budget traditional knives for the most part using a basic 440a steel with a good heat treatment in my opinion.
AG Russell, they make good knives and have a warranty second to none.
There is nothing wrong with Spyderco Bug line or Kershaw Starter line. It's just that if you avoid them you will probably end up with a steel more widely used with that brand and you have a better idea of what they have to offer. Kershaw being 8cr13mov, Spyderco uses that in their Byrd line as well. Along with them using vg10 in my of their knives and severeral other flavors of steel.
Now that's only part of what's needed. Sharpening is the next big thing. A lot of people swear by the Spyderco Sharpmaker, but you can get just as good results with a diamond Lansky Turn Box and drilling some 15 degree holes in it to match the Sharpmaker. And the rods you finish on with this may be a bit coarser than the medium Spyderco rods but that doesn't affect the sharpness it affects the finish. A coarser finish will result in a more toothy knife that excels at slicing compared to one that's taken to a higher grit that excels at push cutting. I own a Sharpnaker with the diamond rods and ultra fine stones, I dont use the ultra fine stones and having bought my wife the turn box before we were married I can safely say the turn box would've been a cheaper solution that work just as good one you change the angles. If you don't feel like the extra work, AG Russell makes a similar system with the 15 degree angles preset.
As to why I'm pushing the sharpening system it's quite simple. Cutting performance 15 degrees is a happy middle ground for most of us on the more "higher end" knives. True higher end knives can handle much more acute angles but this is a happy middles ground for sharpness and still leaving some meat on it so you don't easily deform the blade if you abuse it a little. There is a lot of cutting performance left on the table when you get a knife for the most part. Very seldomly does it have a proper edge, look up sharpie trick and how to use a Sharpmaker and it would help with any of these sharpening systems I mentioned.
Good luck on your knife hunt and have fun.
Define small.
Coin pocket sized?
Front pocket loose carry sized!
Front pocket clip carry sized?
I think it comes down to what do you want to do with the knife?
Also, what is your definition of "reasonable small" ?
Based only on my personal experience, if you are looking for a tool and not a posh "safe queen", then:
Ontario Rat 2 in D2
Spyderco Persistence
Other than that, start watching Nick Shabazz on Youtube....
However, I recommend you go to a store and feel the knife before you purchase, you might not like a liner lock, you might not like G10, you might like carbon, but not titanium. Only you can say...
+1 on the idea about a small Sebenza if you can afford close to $400. If you have to keep it low-cost, you’re not too concerned about blade material and you’re OK with a flipper, a 3” Kershaw Nura is >$20. If you want a ~$100 nearly universal stand-by, the BM 556 is an idea and if you can afford ~1.7x that much, the 556-1 has better blade material. Overall, the possibilities are endless and 100 BF posters are going to have >90 suggestions unless you can narrow down the characteristics of what you want.
If you’re going to be one of those who starts modest and moves into better and better before too long, get the Sebenza. You’ll be at your destination a lot quicker and without filling a desk drawer with folders along the way. I started ~4 months ago and my first Sebenza is scheduled to get to me tomorrow. Happy trails and good luck with whatever you end up doing.
So let's note dimensions.
Out of all the knives I've ever tried and I'm getting into the 100+ folders at this point.
If I were to choose one knife for general edc it would be the Kabar Dozier. I like it so much I bought a real Dozier but didn't like the real thing as much.
The Kabar gives you a super slim to carry 3" blade in a grippy scale material at 1.6 ounce carry weight!
Unbelievable! It's hard to beat that but then you go down the rabbit hole of blade material, purchase, comfort in light of duration of use, hard use (hah hah spec). Most days for most ppl an Alox Cadet is perfect. The problem lies if you just like knives and think they are interesting and fun. It's game on if that is the case.
