Jesus, man. That's beautiful work. I...I think I need a Tuff Lite now.
Thanks, you're too kind. I just started whittling this spring, and it's been a fun learning experience. I've carved a lot of little projects using mostly Tuff Lite knives, often while I'm on conference calls for my day job, or in the evening while sitting out back:
Interesting Greg. It's really different in shape to anything I've ever used to carve, but I've started reading and watching some reviews and seems a lot of folks are using it with great success. Ultimately I need to hold one and see what it feels like to me. I know everyone has a little different technique...I use both thumbs to push the spine usually. I feel that gives me tons of control and I guess I could see that working with the tuff lite.
Btw, nice ball in ball! I like the pattern.
Also, I noticed spyderco makes a knife similar in design (thou much more expensive) called the equilibrium. Anyone ever used that?
I cut using both thumbs all the time with the Tuff Lite--I find the round shape to the blade gives me a nice lever action for controlled short power cuts, with the left hand holding the wood and left thumb playing the pivot, and the right hand and thumb on blade spine providing the lever action.
As far as carving with the Tuff Lite goes, I know it looks and sounds wrong, but I swear by it at this point and would suggest "don't knock it until you've tried it" should apply. I started out with a traditional whittler pattern, a GEC Tidioute #54 IIRC, and while it cut wood it didn't make me that happy. I stumbled on to the Tuff and Mini Tuff and loved working with them, but felt silly whittling with Cold Steel knives. So then I proceeded to buy a couple of hundred dollars worth of dedicated wood working knives--only to find I still prefer the Cold Steel knives . . .
I've seen but not purchased the similar Spyderco designs for two reasons: the Tuff Lite when locked feels about as close to a fixed blade as a folder can, and I trust that Tri-Ad lock completely. Second, the Tuff Lite is cheaper, and carving every night means stropping multiple times daily and sometimes sharpening every day or two as well. It's easier to not mind removing metal daily from a $25 knife than a much more expensive knife.
If you try a Tuff Lite or Mini Tuff Lite, make sure to round the spine/soften the gimping a bit (if not a nice full half round, at least file or sand the sharp edges off). Doing this will greatly improve whittling comfort. As you can see, I also like to paracord wrap and then athletic grip tape wrap mine for extra long term carving comfort.
Don't forget to take a wander over to
The Workshop, where you'll find plenty of whittling and carving gear conversation . . .
