ragnoor:
From the behavior I have seen so far with the Admiral steel, I wouldn't worry about using it in a knife. As quenched 63.5 HRC is not too shabby for a good bowie. Carbon percentages can affect edge holding in the form of excess carbides, or lack of, but most folks never mess with this sort of thing anyhow. All the steel I purchase is annealed when I recieve it, the differences I am noting is after it has been heated to critical and allowed to cool. If the stuff resist impact, like L6 should, then the shallower hardening would be a blessing to folks with simpler equipment.
C L Wilkins:
Your post shows what I was saying about the moly, you will notice a deviation in the ammounts of the various alloys, as mete described. There is a wide range in which the given elements can fall and still make it "L6" this is what makes each manufactures alloy "unique". Between Carpenter and Crucible, the differences appear minute at first glance but a difference of .35% manganese can have radical affects upon heat treat behavior, but the additional chromium could make up the hardenability, but not completely. That dash of moly, however, is a HUGE difference. It will lower Ms, push the steel right over the top in deep hardening and make it keep that hardness at a higher temperature, changes all of your tempering temperatures. But these differnces are between manufacturers, while a manufacturer could get away with dropping elements or changing percentages, I don't think their high dollar customers would be very happy if suddenly all of their proceedures had to be reversed and changed to accomodate a batch of steel that is radically different from the last. I believe it is called "quality control" and it can make or break manufacturers of any product.
The confusion here is that, Admiral gives Crucibles chemistry for their L6 , yet it is in flats. Crucible does not produce L6 in flats. Now of course anybody could have a steel rolled to a different shape/dimensions and then sell it, but its behavior is not consistant with what I have experienced with Champalloy for over a decade now. Could it be Carpenter L6? Carpenter makes the stuff in flats but not less than 1/2" and the chemistry doesn't match at all.
Crucible and Carpenter are the two major manufacturers of this steel that I am aware of. Did Admiral get some L6 made up for them by some other mill? Could be.
As I have repeated here, this steel appears to work well for our purposes, the fact that it is not a duplicate of Champalloy is not a bad thing, unless your heat treatment procedure is geared towards that chemistry. If it has shock resistance, and gives a nice contrast in damascus, I would say that it has definite advantages over RDS or Champalloy for the average bladesmith. I would like to do some more testing because if it does hold up I would start working with it myself, to mix with 10XX steels.
