The Cruciable L-6 is good stuff, but a bear to aneal. I've gotten pretty good results by forging at the low end of the forging temp, tripple normalizing, with the last two normalizing cycles just below non-magnetic, then three anealing cycles with pre-heated 1/4" steel plates in vermiculite, the anealing cycles at just below non-magnetic. You can tell when the magnet just starts to loss atraction your at the right temp to aneal. Then a couple two hour draws in my oven at 500 deg. F. After all that grind/drill quench at non-magnetic and temper, I get the best results with a tripple temper at 375 deg. F. L-6 is a wonderfuly tough steel.
I don't know about the Admiral stuff, and most of the saw blades I've played with worked like 1075ish with nickle added.
