It has been my experience tha gorilla glue doesn't hold up well to moisture. My test scales fell off when soaked in a bucket of water for extended periods. Barge cement out-performed gorilla glue... 5minute epoxy did well (but the bond life sucks, apparently) and West Systems is still going strong. I recently read about Acrylglas and plan on checking into that.
Rick
Rick
how does the Gorilla Glue 5min epoxy hold up?
Where you find Barge cement?
any local sources ?
if you clamp it well the expansion shouldn't be too bad, although when you grind away the exces you might have some open pores on the edge from half ground away bubles. also you can mix it with another glue (Ive only tried liquid nails, and a ruber cement type glue, but i'm sure it will work with most anything) then you can really cut down on the buble some bubles are good, but big huge ones arnt. ! more thing. it works really well if you drill dozens of 1/16 or similar size holes a couple of 1/16ths of an inch into the scale material. the foam fills the holes and you got allot of small pins.
Acra-glas. Never had it fail.
