Question:
Pivot screw out of the box was so loose that I could press my fingertip on the screw cap and unscrew it out.
So I get my 1/4" drive Snap-on torx bit socket and without using a driver, just holding the torx bit socket between my fingers I snug the pivot screw down very lightly.
After doing this I have to pull the blade out the blade is so tight. Can't flick it open with my thumb.
What I discovered it that when tighten down the pivot screw I have to pretty much stop as soon as I feel any resistance otherwise the blade will be too tight.
Basically I can't "snug" the pivot screw down without the blade being too tight. Again, I'm just talking about turning the bit socket with my fingers, not using a nut driver, and stopping a hair after I start to feel any resistance.
The screw had no signs of any Loctite from the factory.
Is this normal? That the pivot screw can only be lightly finger tightened just a hair after you feel resistance before it's too much?
Of course my problem with this, is that since the screw is not really "snugged" down, it's almost sure to be loose in no time.
I know a lot of people are using blue Loctite on the 940's but is it normal to only be able to tighten the pivot screw down until you barely feel any resistance before it gets "too right" and you can't flick the blade out?
First Impressions on the 940-1:
This knife is incredibly lightweight.
Blade seems pretty well centered (a hair off).
I was hoping the 940-1 would be really sharp out of the box and while it is "sharp" but it's not are sharp as my Volli was and I don't think the 940-1 was as sharp as my Barrage or mini-barrages either.
Even with he pivot screw loose it's just not as easy to flick the blade out as I thought it would be. I know a lot of people don't like Assisted opening knifes but within a few minutes after opening my 940-1 I unlocked the blade and it fell under it's own weight (something my Axis-Assist knifes won't do) and caught the tip of my finger and drew blood. Just a nick but I had only had the thing out the box for a couple minutes!
I think I'm spoiled with the Axis-assist. This is my first NON Axis-assist Benchmade. I have a couple mini-barrages, a barrage, and a Volli.
I was hoping I was going to really love the 940-1 but honestly I still like my Volli better. It feels better in my hand and the blade opens so easily.
I think I may end up putting the 940-1 on EBAY and wait for a Blue / Black G10 handled Volli that I KNOW Benchmade is going to make any day now because they want my money
