Getting a 302 was a matter of time because I liked its simplicity. Single blade knives lack the versatility of different size/shaped blades, but they are comfortable to grip and have a spartan elegance. I'd been eyeing the dymondwood models for some time, but this yellow delrin version came up used at a price I could not pass up. It showed up in very good condition. Aside from small dings on one bolster, my Solitaire was like new.
I already had a 309, so I had expectations of its larger sibling. I was not disappointed.
The Good:
Walk and talk - Snaps open and closed with authority, but not a nail breaker.
Fit and finish -Smooth transitions between scales and bolster, nice polish on bolsters and springs, no rough edges. When opened, spine/spring/bolsters are all flush :thumbup:
Strength - One piece bolster/liner is solid and confidence inspiring
Ergonomics - Very comfortable handle contours. I do not mind the thinness. Carries nicely in pocket, but at the limit for me lengthwise.
Looks - Beauty is in the eye of the beholder, but this is one handsome fella. Delrin is a pleasing shade of yellow, and the partial hollow ground clip blade looks nice in these proportions. I love the simple, clean lines.
Made in USA
The Bad:
Blade grind - Grind on one side runs out, so tip actually has no edge (see photo below). Knowing this is done by hand, I am not too bothered by it.
The Nitpicky:
-When closed, spring is slightly sunken at pivot.
-Handle too long - I know this is using parts from the 301, which has extra blades, but the handle is at least 1/4" too long, which is a plus if you have really huge hands.
-There are some uneven corners on bolsters, but 99% of the time, you will never notice this.
-Badge feels like it will fall off.
Easy, big fella! With 309, Case 32087:
All-purpose sized, with 444:
Who da man? With 345 large Vantage:
The thin men: 302 and Victorinox Bantam:
Conclusion: Overall, I am pleased with the 302. It's a good size for general utility, and is good looking to boot. I'll have to sharpen the tip, which should not be too much work if undertaken with care. There is just a hint of blade play, but since I purchased this knife used, I cannot fault Buck for this. This knife will be EDCed, maybe as the only one for a month.
Allow me to describe the feeling of holding a Buck knife for the first time. It never knocks me out at first sight, but then its workmanlike charm takes hold. After I handle the knife for a while, and examine the details, I find a lot of things Buck got right. There is always something to tweak, but that is always so for knives at this price point. I look at it as a form of bonding. Thanks, Buck, for doing what you do.
The Good:
Made in USA
The Bad:
The Nitpicky:
