Well... it will also cut cardboard, wood, various food-stuffs, plastic (as in soda bottles), synthetic/nylon rope, string. I used it on all of those things before I sent it in, and it would hold the same edge that it started out with (ie, sharper than ATS-34) pretty good. I once opened up one of those Guiness Tap cans with it, cutting around the side (not the top or bottom), and it didn't lose a noticeable amount of edge. It stopped it from shaving, but it would still scrape hair. But, like I have said, one hit on a staple (magazine size), there was quite a bit (IMO) of edge rolling. Enough to make a niticeable nick in the blade. In fact, looking at blade now, it
appears that there was a bit of loss of metal near the tip when Spyderco sharpened it; I'm assuming that was getting the edge uniform all the way out to the tip, where it had hit the staple. I say that there was a bit of tip not gone mostly because the grind line, between the back swedge and the hollow portion of the grind, no longer lines up right on the tip, but is a little below it. I doin't remember it being this way before.
Anyway, back to the edge holding. I mentioned the aluminum can above. And that the Native would still scrape hair. Well, I did a
similar thing with my Nimravus Cub: I needed to 'destroy'
a coupld of paint cans, set for disposal. So, I punctured the top of the cans with the Nimravus, piercing the top with about the first 3/4 inch of the blade. Afterward, I tried just for grins, to shave some arm hair with that portion of the blade. Well, it wouldn't "shave," but it would scrape hair, similar to the Native. One thing to note, though. The 'primary' (?, the edge) grind on the Cub is a quite larger included angle, so that probably helped it.
Anyway, like I said, I like the 440V, and would highly recommend the BF Native to anyone. Sorry that took so long, but if you have any more questions, or if I'm still not being logical, please say so; I'll re-examine what I'm saying/thinking.
It's just a ****ing staple!
Outlaw_Dogboy, Pax River NAS, Republik of Marilundt
