I posted a while back about sending in a new Buck 301 because of some side to side play on a couple of the blades. I can't remember the exact date I sent it in, but I received it back today. I think it took 4 weeks or so. According to the packing slip, my knife was listed as non-repairable, so they replaced it with a new one. It came without a box, just wrapped. The main blade is stamped with the same date code as the original (2008), but the blade is a little different. Specifically, it is a little narrower, and the nail nick is much larger. The main blade on this one is tighter than the one I sent in. It has a very small amount of side to side movement (less than the one I sent in (or the second one I bought while waiting), but as Ive posted previously if my limited experience is representative, then I think that this is common with the Buck 301, and not severe enough to be an issue for any but the most picky. Overall, Im satisfied with the new knife, and I have no complaints.
Now for the interesting part. Along with the new knife was a second much older Buck 301. It is the older type with the long narrow nail nick and "BUCK MADE IN U.S.A" stamped on the tang. No date code that I can find. The other two blades are marked "BUCK". It is beat up with the scales worn mostly smooth, and all of the blades worn down by a lot of sharpening, and when opened it is obviously broken. The back spring is pushed down, and the left side scale is separating next to the blade. The main blade hangs down a little. On the box was written, D-J Loose blade keepsake. I guess Buck wanted to show me what a loose blade was really like
. Kinda neat though. This knife has a history, and it looks like someone put it to good use. Ill add it to my basement collection.
Buck makes I nice knife.
