Got my Edit!
Got back from a trip, my Edit was included in the overload of mail. Classy Boker Plus black box, the artistic little fob came attached, and included was a black-coated bead chain to be cut and sized later.
As expected, the knife is a suberb piece of engineering and design. I always doubted the original Subcom Fixed because of the size and material, the Edit read my mind with a durable blade coating and more comfortable curve. While most small knives include a fob for gripping, the Edit's tassel doesn't strike me as essential for drawing, but it does have a certain flair to it and I'm keeping it on. Later on, I may consider taking off the 'legs' of the wonderfully tight monkey's fist, it would offer the same grip advantages but would be easier to carry casually without the cords flopping around.
Wearing the knife around the neck over a dark shirt, it's certainly low-profile with the exception of the little paracord octopus guy hanging off it. Even sheathed it's got a perfectly flat profile with rugged etching along the top. The cut-away handle may allow for cord-wrapping later on, but for now it provides a nice grip. The silver text on the blade, including the CLB logo besides the Boker flag. Some rougher handling in some chores hasn't so much as smudged the finish, if they used this process on the Subcoms I'd gladly pay extra for it.
While the angle of the thing may resemble the Trance, the feel is very close to my Subcom variants despite being thinner and more stable in the smaller fingers. I'd love to work all day with this thing, good control and stability, definitely a worker of a knife. Only thing I don't like is that it isn't a Wharncliffe blade, but then again I'm in the minority there, and those blades just don't look as good as the Subcom leaf ones.
The sheath...Excellent at first. Lot of mounting holes, some zip-ties ought to make a makeshift belt attachment if needed and it'll allow a very different angles for neck-carry or a Mercharness. Then, I jumped over a pile of boxes and heard that scary ringing clatter. The knife did pop out of the sheath while I was wearing it, but didn't hit my feet or anyone else. May have flattened the tip slightly on impact, but some Sharpmaker stones seemed to have straightened it out again. Examining the sheath closer, it's a clamshell design of two plastic molded sides, stuck tightly together with the metal grommets keeping them tight. Very secure and stable, except for the extension of the sheath that drops down below the grommets, down over the spine where you'd place your thumb when you grab the knife to draw it. This little thumb ramp on the sheath has nothing keeping the sides together except the tension of the grommets throughout the rest of it. So, with the knife in it, you can see the plastic sides being split apart, leaving open air between sheath and knife. Pinching off the split entirely would make the sheath unusable as it provides the flexibility of the sheath and is obviously meant to be there, but if something kept it just a tad tighter...Glueing it isn't an option obviously, I'll try an elastic band at an angle across the sheath. It's not an integral flaw, on paper the idea would work fine, but it's just not tight enough in the one I got. Testing it now, the knife stays put most of the time. but something like landing after a jump pops it out. I'll try my inner tube band idea at first, but any ideas are welcome in making it tighter but not sticking me with a knife that may as well have a trigger lock on it.
Besides the sheath issue, the knife itself is fantastic. I'm trying to figure out ways to mount it, such as something to pin it in a jacket or onto a pack strap, or even a pull-cord for pocket draws. While it conforms to Illinois laws by size...I'm not walking down the Magnificent Mile with a neck knife out, and the sheath issue doesn't lend itself to under-shirt carry. This will be my new 'Stare all you want, I'm handy' knife for the outdoors, chores, projects, any time where having a knife on your neck isn't an issue. If I can work out a concealed carry method, even better.
This knife is small enough that I'd feel comfortable using it discretely in public as it doesn't scream fixed blade. As much as I respect my Wharcom in training and in heavy use on cord, cardboard, vegetation, and other tough culprits...The real moments where I love the thing are when I can covertly deploy it in the open, cut my pizza (my local pizzeria provides butter knives with no actual edge to cut this coal-fired crust) and hide it again without anyone at my table noticing. This Edit, despite the Special Forces-esque (High-performance, but unique) appearance, may fill that same niche in a people-friendly (or people-unnoticed) knife for around town as well as for hard work.
In the coming weeks, I look forward to adding a Keycom to join my Wharcom and Edit. Thankfully I'm moving away from jobs that require more labor, so a Hyper isn't needed. Wanted and highlighted on my 'If she lets me' list, but not necessary. For now, I'm tinkering with my hours-old Edit and very satisfied with it. The Direkt seems to be taking the limelight with it being one monster of a folder, but for those in the small fixed blade niche the Edit is a fine knife.
Aloha Alex,
GREAT review, and dead on!!! My sheath was a bit loose also. Wassup wit' dat?!! I plan on hollowing out some paracord and lacing it the top mounting holes, to tighten her up a bit. I already addressed this sheath concern with Boker.
I plan the same method of carry, either MercHarness or small Tek-Lok.
I am very happy you are enjoying your EDIT, and do keep us posted on it and others should you get them.
God bless and mahalo again for your review and your support!
MercHarnass is like ketchup, goes well with almost every kydex sheath dish, and Edit being French fries ;)
Anyway, great review. Hope to get my Edit soon.
That's quick:D:D:D
PS Daywalker, I beat you on the Rampage ;)
The knife itself is surprising me as time goes on. This knife is indeed light and easy to hold, but the true beauty of it doesn't show until you're really overdoing it. This is a strong blade. Not because it's a fixed blade with a bare handle, I've handled 420 skeleton blades that I could flex back and forth with my hands. 440C is just a tank of a steel, and still has decent edge capability. I had to pick between 440C and S30V recently, went with 440C because of its durability. This steel goes with the Subcom-line like chocolate and peanut butter.
I knew the knife would be strong, but didn't expect it to be this solid. Surely people have noticed the lack of blade play in the Subcoms because of ths very wide blade and short length. Whereas other knives bend like filet knives under pressure, the Subcoms don't have enough blade to flex. The Edit takes this quirk all the way from the point to the handle. Yes it's cursed with a short blade, but it might be stronger than a Ka-Bar itself 'pound for pound'. I'd prove this by jamming it in a tree and standing on it, but...eh...well, the blade's so short it would gouge out the wood, and the handle is too small to fit my foot on. As you can see, strength from this design comes at a cost. Make it bigger to compete with traditional knife lengths, and you'd have a handle you couldn't hold realistically and a blade wider than my wrist. Wherever this concept came from, it really is the biggest it can realistically be.
Carry wise, I'm realizing the accessories coming with the Hideaway Knife I ordered may be very compatible with a knife and sheath this size. The belt-mount is out, with a smaller waist anywhere I'd mount it would end up with the handle jutting out at an odd angle. More likely, these 'Sheathstick' things for mounting a sheath in or on clothing. With a couple extra minutes, it'd be possible to mount the sheath inside my front pocket. Then there's the option to put it on my hiking pack strap, and inside a jacket. HAK is a fine design (my incoming straight model is specifically meant to match my Wharcom), but these accessories they came up with have a lot of potential with more mainstream blades.
Enough of my cold design and feature analysis. While it can't baton, the outdoors types I've shown it to flocked to the strong design but disliked the tactical black. When I explained the corrosion resistance, they flipped around to wanting one with orange scales. Then there's the everday-folk (I increasingly dislike 'sheeple' generalization) who have been over here since I've had it, who seemed more interested in the shape, larnyard, and size than the fact this is a black-bladed fixed blade. The curve and the fob has people trying to guess its national origin, I've heard guesses such as 'Arabic' and even 'Native American'. I just corrected them with 'Hawaiian', only logical explanation I could think of.
Aloha Alex,
*Ahem*...don't you mean, "whom" this concept came from?:D
I am glad that you are discovering the "power" of the EDIT. Also, all that you posted in your last paragraph I have been experiencing the same response.;)
Now, if you don't mind my adding to your EDIT thread...
Welp, I tried tying a small, hollowed out piece of para in the first rivets of the sheath to try to tighten her up a bit. It "kinda" worked, but not as tight as I would like. Anyway, sheath issues aside, I went into the forest area of my backyard and found a very seasoned piece of wood. I had the EDIT in my pocket and decided to whittle the stick I found on one end to a point. I tell you, this lil' EDIT did an excellent job at this, and the wood put up a lot of resistance because it was so hard. However, the EDIT was comfortable during this task. I was curious on edge retention and also about this Ti-Coat that the EDIT wears, to see if it would hold up like my M-TYPE's have. Some in hand pics:
As I whittled away, I noticed something on the blade..."Aha! Scratches!!!"
Nope. They were just "marks" from the wood. I wiped away the "scratches" with my fingers. The Ti-Coat holds up perfectly. Edge retention after whittling away at this stick was great. It could not shave hair afterwards, but was still plenty sharp for ANY other task...so long as it was not shaving that is. I am very pleased at the how well this lil' EDIT felt in hand during cutting, and like Yoda from Star Wars, this EDIT might be small, but it is powerful!!!
Going OT, I had the DIREKT ME on me as well, so I went at it on the opposite end of the stick. Worked just as good, and the ala Carson Flipper did not get in the way at all. One thing that already has been proven to me by my "ME" (Midway Edge) Opinel #12, was that I was glad the SE portion is where it is on the DIREKT ME...I have whittled with SE, but it wrecks the teeth and pain to resharpen. So the Midway Edge worked well, no scratches on the blade, and it took the same amount of swipes on my Spyderco 701 White Stone to bring them both back to shaving sharp: 4!!!
The EDIT is an awesome knife, and um, going further OT...am I the only one excited about the Clone Wars coming out in August?:p
God bless you guys, and mahalo Alex!
Can't help to compare the EDIT with CRKT TRIUMPH NECK
Some sandwiches...
Last sixpack before your AA meeting
Aloha MOI,
WOW! Nice knives! How the heck did you get a Rampage??? How is that one in your opinion?
God bless and mahalo my friend!:cool:
Aloha MOI,
Thx bro. How the heck I got a Rampage??? I was asked the same question by one of the bigger knife dealers in my country, and the answer is simple: the same way I got my (sadly defect and returned) Direkt - ordered at the local weaponstore, arrived within 2 weeks. Usually I'm one of the first to get the new Böker releases, (if I've ordered one) but this time the KeyCom is taking too long:mad:
About the Rampage, one word: WOW!!! Great ergos, agressive look, extremely well built for snap cuts and ripping while retaining the penetrating power, nice steady thick blade. The micarta handle is not to smooth and not to rough, just enough to provide the comfortable grip needed and the sub-hilt on this one is a dream.
Furthermore I'm especially fascinated by the grind on the back of the edge, very original... okay, I've also seen that on CS scimitar and tokyo spike. (I got the tokyo >_< )
Hopefully you can get a idea from the pix. Sorry for the bad quality of my pix, made with my mobile phone (no fund for a decent camera, and you can guess why;))
I hope you get your sample soon, in the mean time, you can keep bugging Terry:D Take care.
I spent a few days walking around the city with my Edit in a Mercharness underneath a baggy tee shirt. I attempted to cord-wrap the handle, looks terrible but keeps the cold metal off my skin and is comfortable for extended use. Combined with the larnyard which I trimmed back to a respectable little spider instead of a giant squid, my Edit is starting to take on its own urban-based personality. If I had the right perch, I might take a picture of it along the Chicago skyline along with some other knives. (Expect my new black Keycom posed next to the Sears Tower).
The sheath still feels loose, but I ran around with it for days under my shirt and I still have both my kidneys. However, I have some ideas using the Hideaway accessories I mentioned to mount it on my belt behind my back. Odd? Yes, but even with its smaller size the ergo-handle makes it very easy to draw in that fashion. Also, as great as the Mercharness is, it's designed for layered clothing. It's no problem drawing, but re-sheathing requires me fumbling around with both hands inside my shirt like I had an animal in there. Once I get it together, my Bat-Belt idea may turn my Edit into a semi-EDC. It's quite a twist from an elegant Hawaiian neck-knife to something cut down, wrapped, and concealed like a sawed off shotgun from my city's less glamorous days. Pictures will come soon, both the postcard shots and the carry rig.
Great that the Edit works fine for you. I was tempted to swith out the Merc-Harnass off the CRKT Triumph NECK to the Edit, but then I realised that I have no need to EDC a small size fixed blade while EDC-ing 2 solid folders, i.e. EKI Mini Com and the Trance. They make helluva combo and cover all my dailey chores with ease, yet I need not worry about the locks. On the concealablity issue, no body will notice them as long as my T-shirt covers them. Gonna try to clip the KeyCom on my small jean pocket tomorrow, is that overkill?;)
Anyway, I might switch the Merc-Harnass on the Rampage and EDC that. Boy I am gonna have trouble with the law:D
Alex,
Thanks for the EDIT review . Very informative.
According to Beagleboy from Messerforum who works in sales for Boker:
people with first Batch Edits can have there sheaths replaced.
He says the first batch had bad sheaths and later Batches have better sheaths with improved retention.
If Terry/Tobias can confirm this?
Cheers Maarten
how do you know if yours is from the first batch?
anyone made/bought a sheath out of kydex for theirs?
They all have production numbers on the blade. So i think the Co. will now if they are first batch.
I am still waiting on confirmation from Tobias or Terry on the replacing sheaths matter.
Cheers Maarten
I heard Mike Sastre makes good kydex or CF Custom sheaths on your side of the pond. You might try a custom sheath if you don't like zytel sheaths.
