bigfish44 said:I finally figured out photobucket, here's a pic
chickentrax said:Did anyone else notice that the rockerbar on that Damascus bladed knife is different from other 110's??? There's no "tooth" on the end...
bigfish44 - does the blade have a "notch" in the tang??? How does the blade lock in the open position???![]()
Carl64 said:Normally the notch is not visible. I have one 110 that has a thinner lock bar than normal (or maybe the notch is cut deeper, depending on how you look at it), which I am thinking about sending in. All of my other 110s do not reveal the notch when opening.
KeithAM said:I think you're seeing a strip of reflection of the red surface on the bolster. Look at the other bolster to see what I mean.
DarrylS said:I never had too much interest in the Damascus blades. Just not that great at being a collector I guess as I use most all of what I've got around ...Am I correct at assuming that you can get truly gorgeous Damascus or just basically marginal Damascus as the luck of the draw is what determines what you get?...Gotta admit that I've seen some absolutely beautifully patterned Damascus that I would find really hard to turn into an EDC...Sure would like to see your's too Tom...![]()
