- Apr 3, 2013
I got some new Venev stones from Konstantin of gritomatic to test out and review,what I got was 2 1500 grit and 2 2000 grit dual sided stones.
I sharpened both knives with my metallic CBN stones starting with 80 and 120 grit then I moved to the Venev 240 400 800 1200 and then moved onto the 1500 and 2000 grit stones I received.
I used my TSProf K03 to sharpen these knives.
This is a picture of the scratch pattern I took for comparison before moving onto the 1500 and 2000,the knife is a Manix 2 in M390.
These are picture's of the experimental resin and the first picture is the 1500 grit yellow stone and the second is the 2000 grit red stone.
These are pictures of the OSB resin stones I also received for testing,from what I understand the OSB resin is already being used in some Venev stones,the first picture is the 1500 grit OSB and second picture is the 2000 OSB resin stones scratch pattern.
The knife in these pictures are a Manix 2 in M4.
From what I found of the experimental resin stones is that they cut extremely slow and hardly and swarf at all was on the stones after sharpening with them,where as the OSB stone removed metal faster for sure.
I understand that when it comes to stones that are 1500 and 2000 FEPA grit and 6000 and 8000 grit Jis when converted from FEPA but the experimental resin just wasn't hardly doing anything at removing metal at all,the experimental resin did improve the sharpness of the edge a bit but not as much the OSB resin.
If I were to choose between these stones I would go with he OSB resin because it gives you a sharper edge,the scratch pattern of the OSB looks a lot worse in the picture then it does to the naked eye and any scratch's left over could easily be removed with a Chosersa 5K or Suehiro G8 8k stone.
