- Dec 10, 2005
Excluding ceramics, I make the best non-metallic knives available. They are made of GPR (glass phenolic resin). These knives are approx 4-5 times stronger than G-10 knives and approx twice as strong as carbon fiber knives.
Granger Knives and Pale Horse Fighters
GPR Military and Police Knives
We are pleased to introduce our line of GPR non-metallic knives. GPR is a fiberglass and phenolic laminate that looks somewhat like micarta or G-10. However, it is considerably stronger. It is attractive, black, can take a high polish or a satin finish, and is not affected by moisture or heat.
Why a non-metallic knife? A GPR Knife in a stitched Kydex tm sheath is lightweight and can be carried very comfortably. In a neck sheath, it can be tucked away under uniform shirt or jacket and forgotten until needed. Granger Knives' GPR Knives are now carried by some Federal Agents for use in covert operations where a steel knife would be exposed by a metal detector. GPR Knives appeal to undercover police officers for the same reason. The GPR Knife is intended for use as a secondary or covert means of self defense. It is not intended to be a utility knife. They excel at cutting seat belts and the enemies of society and America. The GPR Knife possesses strength and edge-holding abilities far beyond "plastic knives" like zytel tm or G-10.
How strong is a GPR Knife? We wondered the same thing when we first entertained the idea of producing such a product. The raw material is available to us in two thicknesses, 5/32" & 1/4". We tested a piece 7" x 1 1/4" in the 5/32" thickness. We clamped half the piece to a stationary object then bounced 250 pounds of weight on the other half. The piece sustained no damage whatsoever! All of our GPR Knives are milled from 1/4" stock for even more strength. We were impressed and you will be too! GPR Knives have a Rockwell hardness of 47.
Granger Knives' GPR Knives come with either a standard or serrated edge with an aggressive bite. All GPR Knives are chisel ground as this produces optimum cutting ability. Therefore be sure to specify if you are left or right-handed. GPR Knives are available with or without handle slabs. The knife can be resharpened in either of two ways. To preserve the serrated edge, touch up the teeth with one of the many serrated knife sharpeners. To resharpen the standard edge you may use a file. Or better yet, tape a sheet of 400 grit sand-paper to a 1/4" piece of safety glass about 6" wide and 12" long . Tape it tightly so that both edges of the sandpaper go around to the back. Then use it just like a sharpening stone. Sharpen only one side of the knife.
__________________
Granger Knives & Pale Horse Fighters
www.palehorsefighters.blogspot.com
si vis pacem para bellum
en omnia paratis
