Thank you for the answer!Thinner is generally better. The whippiness of wood disperses the shock of the blows, resulting in less damage to the handle over time and making it more likely to bend rather than break, as well as saving your hands from the impacts. However the handle on the right still looks quite thick all things considered.
Thinner reduces rigidity, but reducing the lateral rigidity is the point. It remains stiff front-to-back but is able to flex more laterally to disperse shock. Rigidity scales cubically with changes in thickness resisting the vector of force. So a small increase or decrease in thickness directly opposing a force makes for a massive change in rigidity. So a ruler flat on a table hanging of the edge of a table will be floppy if you push on the end, and making it wider only increases resistance linearly since it's adding material parallel to the force vector. But if you make the ruler just a little bit thicker, it will be MUCH stiffer at equal width than the thinner one was.Counter intuitive but thinner in that direction will actually make the handle stiffer, much like a popsicle stick.
On the other hand nothing is to be gained by making the handle wider than the eye in the neck like the first haft.
There is a balance that a nice oval shape produces so don't make a handle to skinny.
I have no idea what you are saying, but I do know a skinny haft will have hand shock and be whippy laterally at the same time, it's an awful haft.Thinner reduces rigidity, but reducing the lateral rigidity is the point. It remains stiff front-to-back but is able to flex more laterally to disperse shock. Rigidity scales cubically with changes in thickness resisting the vector of force. So a small increase or decrease in thickness directly opposing a force makes for a massive change in rigidity. So a ruler flat on a table hanging of the edge of a table will be floppy if you push on the end, and making it wider only increases resistance linearly since it's adding material parallel to the force vector. But if you make the ruler just a little bit thicker, it will be MUCH stiffer at equal width than the thinner one was.
I also know that if I double the depth of a beam I have increased it's load carrying by eight times whereas if I double the width I have only increased it's by double.
I wish you luck should you ever try some wood bending experiments.Yes, this is what I'm saying. Changes in thickness resisting the direction the force is coming from have a cubic scaling effect. And it's why basically all vintage handles for any tools have a thin zone in them between where the head is mounted and the primary gripped portion.
Reducing the lateral dimension will not make it stiffer.
I'm in the midst of a bunch of them, actually. But you're likely confusing rigidity for the introduction of instability and side loads. Those are completely different from stiffness and have more to do with changes in the direction of force.I wish you luck should you ever try some wood bending experiments.
I'm not the one that is confused.I'm in the midst of a bunch of them, actually. But you're likely confusing rigidity for the introduction of instability and side loads. Those are completely different from stiffness and have more to do with changes in the direction of force.
The simple fact is that making it thinner in that plane does not increase rigidity, full stop. It just doesn't.
Please provide literally any engineering source that indicates that reducing thickness actually increases rigidity. A single one.I'm not the one that is confused.
No.Please provide literally any engineering source that indicates that reducing thickness actually increases rigidity. A single one.
This is frankly a petulant and ridiculous response. You made the claim. The burden of proof is on you. It's okay to admit to being wrong. I have done it here in this very forum plenty of times as I've learned from our fellow members. If you can find me one engineering source backing your claim I'll concede freely that you were correct. But I find it vanishingly unlikely in this case. Making a thing thinner is not going to increase its rigidity. That's simply not how it works.No.
Gain some knowledge, experience, and figure it out on your own.
Any reason design like this? Maybe because of actual use scenario?
In the absolute strictest definition of stronger? No. More material is always going to resist more forces.Counter intuitive but thinner in that direction will actually make the handle stiffer, much like a popsicle stick.
