Grain size affects yield strength
BluntCut MetalWorks
How grain size affects yield strength could be a useful fact to know/aware of. It won't give you definitive yield strength value for particular specimen but will provide a reasonable value within empirical range. In simplistic view...
ref: http://en.wikipedia.org/wiki/Grain_boundary_strengthening
Key formula (sigma_y = sigma_zero + Ky / sqrt(d)), where sigma_y = yield strength (YS)
Example 1: Mild Steel
Using Hall-Petch constants table (on wiki page) (sigma_zero=70MPa, k = 0.74 MPa sqrt(meter)) and compute YS for grain diameter of 100um vs 1um
YS_100 = 70 + 0.74 / ((100)^-6)^1/2) = 70 + 0.74 * 316 = 304MPa
YS_1 = 70 + 0.74 / ((1)^-6)^1/2) = 70 + 0.74 * 1000 = 810MPa (~117K psi) <= 166% stronger than sample with grain diameter = 100um
Example 2: 52100 at 60-67rc range, where known YS_15 (grain diameter ~15um) is 2000MPa
I couldn't find concrete sigma_zero & k values but worked backward with very conservative estimated values: sigma_zero =~1500, k = ~2
YS_1 = 1500 + 2 / ((1)^-6)^1/2) = 1500 + 2 * 1000 = 3500MPa <= 75% stronger 52100 with grain diameter=15um
Otoh, it could be a meaningless number in a larger scheme of knife-making.
A complex way of describing what many of us have been told. :D
Please do share HP coefficient values for variety of steels & alloys. Hard to dig up these numbers so we can quantitatively figure out yield strength for certain grain size.
Maybe you or someone can shed insight (formula & coefficients) for plasticity affects by grain size? I am searching but only found vague references. :thumbup:Thanks.
No, that is the COMPLICATED part. What we have been told is that small aus grain makes for tougher blades. ;)
Touche'
Well, not a surprise, I don't listen very well. To see for myself. My tests indicated strength gained but loss quite a bit of impact toughness - still very chippy at 60rc. Either that or my samples are bad :o I will do some more reverse-chop (stick of seasoned oak whacks the edge) at 58rc zero grinded paring knife to see what happen...
You betcha - hard to lose when outcome assure winning :thumbup: HSS grain around ~12um, Cold PM low carbon grain can be as low as 7um. Nifty awesome for heavy tonnage of carbide volume.
That must be why I like powdered steels.
edit: at 58rc, test blade is still very stiff & brittle. I can cleanly plier small chunks off the edge and clean break the tip with a vise. Yep, nice crunchy sound, didn't set from bend at any point at all. Tomorrow, I will temper the remain of this 52100 blade at 600F and then 650F after that. Go back to my 3rd post, exact reason why I asked for plasticity affects by grain size :p
