Gransfors Bruks Question
Hey guys, currently deciding between a Gransfors Bruks or a wetterlings Scandinavian forest axe. Since i hear that it is is a somewhat common occurrence for wetterlings to come with off grinds and less than perfect handles and I am only able to order one off the internet i was wondering if the Gransfors axes come with a finish on the handle? I prefer an open handle treated with linseed oil, and if i have to remove a lacquer or something of that nature in order to treat it then it might weigh heavily on my decision between the two as if i am going to have to work on both of them then i May as well go with the cheaper wetterlings. Could anyone with some experience with Gransfors axes let me know about this? Thanks a lot.
Thanks so much! Would you agree that without the ability to inspect the axes by hand that a Gransfors would be a safer bet on quality control?
Yes, Gransfors is usually a notch above. Though I have to say, since one of the owners of Gransfors took over at Wetterlings, their quality has become much better and more consistent.
Is there any real difference between the steel quality and construction of the axe heads themselves?
Both are great. Gransfors a bit better quality. If money isn't an issue then the Wetterlings would get beat out by the Gransfors in my eyes.
It's mostly little design differences that can cause a preference. Examples of 'pairs' I own:
Broad axes- the wetterlings is heavier with a straighter bit/bevel, whereas the gransfors is lighter and more rounded. Steel quality is about the same, finish is a little nicer on the GB
Carpenters axes- Again, wetterlings is heavier, less elegant. I use the GB to carve with, and the Wetterlings for timber/log building tasks. Bevel is longer on the Wetterlings, but grind is very close between the two. GB holds its edge longer, but they do get different uses.
