- Nov 7, 1999
Hi Guys...
Before I was into this survival thing,, I was doing the fishing thing pretty heavy..
Heres a trick I use to use for catching Hoppers,, and a lot of them..
You need two things.. A container to put them all in and a fuzzy blanket...
Doesn't matter what kind it is as long as it's fuzzy...
Go to an area where there are a lot of Hoppers,, shouldn't be hard to find....
Lay the blanket down on the ground spread out.. This works better with several people,, but can easily be done by one,, and you'll be choking on wings and legs before you know it...
Start several yards away from your blanket,, and work in a circle, chasing the Hoppers toward the blanket.
Once you get them on the blanket they are done. Their feet have tiny little barbs all over them and they get stuck to the blanket,, just like Velcro. Pick them off and put them into your container...
The hard part is getting them out of the container without looking several dozen in the process...
If you are going to eat them,,just shake the hell out of them until they don't move,, then roast on the fire...
If you want to use them for bait,, cut a small hole in the top,,the size of a quarter and shake them out,,or use tweezers.. I used small hemos to get them out,,worked great...
Give this a try sometime,, it's a lot of fun and a good way to catch a heap of them all at once!
ttyle Eric - On/Scene
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
Eric E. Noeldechen
On/Scene Tactical
