Grayman knives has been known for its rugged, overbuilt, and near unbreakable fixed blades for some time. The next step of course was a folder and the Satu does not disappoint.
Like many Grayman knives the Satu is massive. It makes other knives look like toys in comparison.
With a CQC-7
With a Super CQC-8...yes a SUPER!
Each is individually numbered out of the intial run of 50
Its certainly heavy duty and came with a good working edge but not shaving sharp. I was able to get it shave easily with a diamond file and ceramic rod.
Some notes of interest are that it takes some time and patience to find the sweet spot with the pivot, where it opens easily but doesn't have enough play for the tip to rub on the liner while opening. The lock up was early and good.
The clip is very tight, a good thing for the very active (running, jumping, etc) and may also have been designed to prevent overtravel of the lockbar but that's more speculation. I'd like to see a MOLLE compatible sheath offered for it but beyond that I'm very satisfied.
From the website:
"GRAYMAN Satu (sah'-too) Folder
The very first Grayman Folder in a limited run of 50. Precision machined from S30V, Titanium and G10. Designed and built tank tough, 100% made in the USA. 10 oz.
SPECS:
3/16 6AL/4V titanium Lockback
1/16 (.063) ti liner
5/32 coarse textured black G10 over liner
.210 CPM S30V Steel blade Heat treated to 59RC, flat ground
4 x 1.5 blade
9-7/8 OAL
.230 black G10 backstraps
Glass beadblasted Titanium clip
400 Series stainless steel hardware
Wire EDM cut locks
3/8 pivot bushing for added strength
Garnet blasted liners and lockback and blades
Laser Engraved: GRAYMAN, USA, S30V
http://graymanknives.com/satu.html
With a CQC-7
From the website:
SPECS:
4 x 1.5 blade
9-7/8 OAL
Wire EDM cut locks
