- Nov 19, 2014
This is my humble attempt to review a traditional knife I have had for a while.
The GEC #73 liner lock with Osage Orange covers.
I have to admit that I am not familiar with traditional knives.
The GEC is my third traditional after a couple of Japanese back locks (Moki and G. Sakai) and the first slip joint (besides SAKs).
I love full Ti frame lock knives and have several of them.
But somehow I have also always had a thing on traditional knives with wood scales.
This GEC #73 caught my eye hard.
Very nice blade and handle profile.
The specs
I bought this knife a while ago but have not used it.
Because..... what a stiff knife!
I could not open it without tears in my eye!
So I left it half open for a while with a hope that it would ease up the spring.
Finally, it began to give in a little.
I also sanded the tang a little.
It is still very stiff, but at least I can open and close it repetitively.
Then, I oiled it, open/close many times, cleaned it, and oiled it again.
Now I can open it even with my sore thumb!
The knife has a nice half stop, which I like for this alligator.
It also has a liner lock bar for added security.
With the strong spring (still), the lock may not be necessary, but I do appreciate the feel of additional security.
The lock-up is about 100%, if it means anything.
There is no lock stick at all (the bar may not actually touch the blade tang).
The fit and finish is superb.
It doesn't look so in the pic, but the blade is perfectly centered.
There is no blade play in any directions.
One thing I am concerned is that the tip of the blade is very close to the edge of the scales.
After some sharpening, it may be sticking out.
The blade is very very slicey.
Thin blade stock, thin behind the edge, and full flat ground.
Together with the narrow blade profile, it glides through cut medium.
Overall, I am very satisfied with the knife, now that I can actually open and use it.
So satisfied that I ordered another GEC slip joint, based on recommendations I got here before.
After experiencing the cut power of this knife, it is difficult to go back to thicker modern knives......
Also, there is a strong satisfaction when I open ad close it with the hard snap sound (called "nice talk"?).
The specs
Code:
Overall length: 175 mm (6.89”)
Closed length: 95 mm (3.7”)
Blade Length: 80 mm (3.15”), 72 mm (2.83") edge
Blade thickness: 1.93 mm (0.076”)
Edge thickness: 0.18 mm (0.007”)
Edge angle: 20 DPS
Blade material: 1095 (carbon steel)
Blade grind: Flat grind
Handle thickness: 12 mm (0.47”)
Handle material: Osage Orange cover, stainless liners
Weight: 78g (2.75 oz)
Lock type: Slip joint with liner lock
Deployment method: Nail nick
