GREAT RUST REMOVAL process
I put together this concept using a plastic garbage can with 6 steel rebars as electrodes. It works great! I am cleaning a mandau (private collection buy, the guy died and the wife put his stuff in the basement ARGH!.)
Should have taken a picture of the blade beforehand, but it was wall-to-wall red rust. After a two day soak, and one or two rubdowns with a plastic brush, most of the rust is gone.
Usiing an old battery charger for the power source.
Try this at your own risk. I am using it on a heavily rusted blade of no great value. There may some adverse effects I don't know about, but it sure looks like it is working well.
Obviously can't remove pitting where the metal has combined with oxygen, but sure seems easier and less invasive than steel wool or sandpaper. The pictures show only the process done to the blade. No steel wool, sandpaper or anything else hzs been used
The solution does not seem at all caustic, but remember it is water and you may not want to get your wood handles wet for a sustained several days. The bubbles do come up and the mandau handle is wet.
http://myweb.tiscali.co.uk/andyspatch/rust.htm
