White is a bit more coarse than green. Either is enough to get a shiny finish.
first white
then blue
green is 0.3micron.
you could do some tests. rub the compoundA on a smooth wood surfaceA, then manually polish a tiny smooth soft metal faceA (e.g. a copper washer, aluminum gasket, AA battery bottom) on it. then do the same with 'B'.Now have a strop and two compounds but not sure which to start with.
red is coarse, white is medium and green is fine.I am new to stropping. I have used the Fine grit DMT Bench stone. Would like something a little more polished. Now have a strop and two compounds but not sure which to start with. All advice is much appreciated.
hmm. strange. my red is just labeled coarse. it does not give micron total. sorry ladI have red iron oxide powder (used by painters to produce their own paints for a painting), it is spec'd finer than green chrome oxide powder. i linked the PDF spec datasheets in one of my 478 posts.
sorry lad
not doubting you sir. just objectively stating what my compound is labeled as. have a good day siroki i let you win this time. because you are new and during the 7 forum years that i am senior there might have been some technological reversing which i coud have missed, god speed.
