I've got the CRKT M-1 by Lightfoot, and the blade profile is identical to the folder pictured above.
The blade profile does not lend itself to penetrating hard objects very well (too much edge area to punch through plywood), but the very pronounced belly and slight recurve is very good for the majority of cutting task. I would also think that as a tactical knife, the problem with penetrating plywood would not be such a problem should your target be flesh and bone.
The CRKt version also has a sharkfin shaped "flipper" which also acts as a handguard when the blade is open. This handguard blends into the fingergroove in the handle very well.
As if that were not versatile enough, this knife also comes with two wide clips with the option of carrying tip up, or tip down... left handed or right handed... that's four options... AND, if you so choose, you can use two clips at the same time... switch between left and right pockets. Tuck your knife in your pocket, or on your belt without a sheath... go back and forth to any carry position you want, the clip is already there...
