It helps a lot Jon, thanks... I'll give it a try tonite.
As far as re-grinding the blade, the Lansky rig seemed the easiest way. I was at it for well over an hour, starting with the rouger stones. For some reason the burr never really completely formed. There was a real slight one when I finished, but stropping it on the back of an old notebook seemed to help a lot. There's a lot more metal showing across the grind now. It's not really shaving sharp, more like a working sharp, but it cuts really well. I thought about doing a regular v-grind, but it seemed like it would remove maybe too much metal that way. Maybe if I'd thoght about it before doing the grind, it would have worked out. If the grind angle is so much more ("duller," if you can really apply the term to an Emerson) then maybe you'd have more luck with a v-grind, assuming there's a primary bevel on the other side of the blade. (Beveled up to the edge, as opposed to a completely flat surface... I can't tell from the publicity photos if it's beveled on both sides like my 7A is.
Other than that, not much I can say, except be patient while you're doing it. The lansky helps some, keeping the angle for you while you're watching TV ro listening to some tunes. Sharpening's not really a good thing to do on autopilot when you're reworking a grnid angle. You can always tune back in during commercials, though.
Have fun, and thanks again.
-James
