Can someone help me understand how a tanto grind is significantly different in regard to actual use than a wharncliffe? Both grinds feature a long straight section. If your purpose in selecting a wharnie is for the flat then a tango satisfies that need. Both feature points for fine cutting tasks. Hell, the tanto has two fine points. While the initial angle preceding the very tip of the tanto is more obtuse than the actual tip, there’s still minimal contact surface which enables fine cutting. Is it the sharpening? Is it simply because it’s over-tactical? Essentially, a single cut bisecting the flat and the tip would give you a wharncliffe. So, someone help me to understand the distaste, please.
