- Oct 29, 2015
How do y’all know when to go to the next higher grit when grinding the bevels? Obviously, it’s when you remove all the scratches from the previous belt, but how do you know definitively when that is accomplished?
Tonight, I put dychem on the bevels after grinding, but after three passes at the next higher grit, it was gone. It’s hard for me to believe that three passes removed all the scratches, so I kept grinding until it looked good to the naked eye, then progressed up the grits.
Finally, I made it to a 9 micron grit belt. Not because I want to put a mirror finish on my knives, I don’t, because they are working knives. But I did it because I knew any scratches I didn’t remove would show up. Here is what it accomplished.
This pic looks pretty good, except for the two vertical scratches toward the front of the blade.
This pic, with the blade held at an angle to the light, shows the scratch pattern better. It’s obvious I didn’t remove one long scratch up towards the front. For the most part, it is a mirror finish, but there are still imperfections. So, how can I know that I’ve removed all the scratches of the previous grit before moving on?
I will ultimately take this knife back down to 600 grit and it will be ok. I’m just trying to perfect my craft and would appreciate any tips y’all can give me.
